heiko_s
Moving Usermanager from one System to another
Sat Oct 13, 2007 9:01 pm
i have an MT Lv5 AC running the usermanager.
The systemload is getting higher and i decided to split the services apart.
For this case, i'd like to move the usermanager to another machine with a lv5.
Is it possible to do it without loosing the whole userconfig?
How is ist made?
Thanks for your help!
Regards
Heiko
itsh.net
Re: Moving Usermanager from one System to another
Sat Oct 13, 2007 9:34 pm
export the config on the "old" system with
/tool user-man export file="userman-backup-export"
and import with copy and paste in the "new" System
Regards
Marcel
sariao
Sun Oct 14, 2007 8:26 pm
or you can just use
to backup the database
/tools user database save
and to restore
/tools user database load
Sariman
sergejs
Mon Oct 15, 2007 1:27 pm
To save all the information from the User-Manager about sessions, you have to use sariao suggestion.
heiko_s
Mon Oct 15, 2007 1:37 pm
THANKS for alle the suggestions - i found it in the documentation for backup and restore!
thread may be closed!
Users browsing this forum: No registered users and 39 guests
