scottyratcliffe
7.6stable-7.7beta LTE quectel Modem disconnect
Thu Dec 08, 2022 11:28 pm
Since 7.6 I have been having issues with multiple quectel RM520N-GL modems keep disappearing and reappearing form interfaces list. It is happening from 3 wAP R ac units. The issue can be resolved by reverting back to 7.5 stable. the log files shows error "mbim: error: wdm send failed: 19" The modem is running firmware RM520NGLAAR01A05M4G
BitHaulers
Re: 7.6stable-7.7beta LTE quectel Modem disconnect
Fri Dec 09, 2022 6:05 am
How are you fitting 520Ns on a WAP R AC? There are some board components that block the mpcie to m.2 adapters, never mind the longer ones for 5G modems. You got any pictures?
scottyratcliffe
Mon Dec 12, 2022 4:18 am
I use a NGFF M.2 To Mini PCIe Mini PCI-E Adapter For 3G 4G Moudle M.2 to mini pcie
https://www.aliexpress.us/item/32568021 ... _shipto=US
the only problem i have with the adapter is the modem is to long for the screw slot so it is held on with a twits tie.
Here is a picture of it.
https://photos.app.goo.gl/pjY5iRK3dWcoMbmS7
scottyratcliffe
Re: 7.6stable-7.7beta LTE quectel Modem disconnect  [SOLVED]
Fri Dec 16, 2022 1:36 am
The 7.7rc1 seems to have fixed the issue, has been running fine on 2 of the 5 units i have rm520n-gl cards in
BitHaulers
Wed Jan 18, 2023 3:04 am
How hot does that get with no heatsink?
Users browsing this forum: 5h4k4 and 38 guests
