stromo
multicast-6.49.7-arm installed or not?
Fri Dec 09, 2022 12:23 am
Hello forum.
Running ROS 6.49.7 on ARM. My package list does not include multicast, and the "/routing igmp-proxy" command is not available. When I try to install the multicast-6.49.7-arm package, I get a log error "omitting package multicast-6.49.7: it is already installed"
If it is installed, then how do i configure an igmp proxy? if it is not installed, then how do i install it?
tia.
mkx
Re: multicast-6.49.7-arm installed or not?
Fri Dec 09, 2022 12:25 pm
In v6 you can check which packages are actually installed by executing command
/system package print
When a package is installed, it can be disabled. If a package is disabled, you have to "schedule it for enabling" by running
/system package enable multicast
followed by a router reboot.
stromo
Mon Dec 12, 2022 4:51 am
I found the problem. A filter on the installed packages. Multicast was installed, but not enabled.
Thanks for your reply.
Users browsing this forum: floresta and 148 guests
