Lesani
getting lots of "loop" logs on the port that my cAP is connected to
Fri Dec 09, 2022 12:59 am
getting
sfp-sfpplus10: bridge port received packet with own address as source address (#mac of my cAP AC#), probably loop
every 5 seconds in my log.
I have one single cable running directly from Port 10 to my cAP AC "ETH1 PoE In" port.
Nothing is connected to ETH2
I have a mAP (Lite I think) connected to Port 6
both mAP (?Lite) and cAP AC are provisioned from my main router (CRS326-24S+2Q+) usinc CAPsMAN
What would you need to diagnose this issue?
sindy
Re: getting lots of "loop" logs on the port that my cAP is connected to
Sat Dec 10, 2022 9:14 pm
As the CRS326 complains about own address as the source address of a received frame, the most likely explanation is that the bridge (or the sfp-sfpplus10 interface itself) on the CRS has the same MAC address like the cAP ac. One possibility is a mistake in production, a more likely possibility is a misconfiguration (you can manually change IP addreses of Ethernet ports as well as of the bridge). So I'd check this as the first thing.
Ca6ko
Long time Member
Long time Member
Re: getting lots of "loop" logs on the port that my cAP is connected to  [SOLVED]
Sat Dec 10, 2022 9:59 pm
The most common mistake in misconfiguring the capsman.
A loop occurs between the physical ether1 interface and the virtual CAP on the access point.
Remove the inactive wlan1 interface on the CAP from the bridge.
Lesani
Fri Dec 23, 2022 11:38 pm
Thanks! For whatever reason I wasn't subscribed to this topic and thus thought noone had answered, I have removed the inactive wlan1 and wlan2 connections from the bridge, and the messages have disappeared. Now as a side effect my cap doesn't have an IP address anymore, but I can still talk to it usinc the MAC. sufficient for me at this time
Ca6ko
Long time Member
Long time Member
Mon Dec 26, 2022 11:13 pm
You have two options
1. Fix the DHCP client settings to the correct ones.
2. Assign the address manually
Users browsing this forum: Amazon [Bot] and 40 guests
