Mohsinali
Nord VPN Disconnection problem with Mikrotik RB750 GR3 Router
Fri Dec 09, 2022 2:25 am
I have connected Nord VPN in Mikrotik RB750 GR3, the problem is its keeps on disconnecting. I have been using a VOIP phone with it.. and a VOIP phone can only be used if you have IP from the USA so I am using US Configuration in the VPN IPSec section. when it disconnects I have to turn off the router and turn it on back to solve the issue. sometimes I go to the setting and change the Router profiles setting in IPsec section. I have no idea what I am doing, but most of the time it works for some time then again problem starts... Can someone please guide me on how can I do this. I have just basic knowledge and cannot understand complicated terminologies. Your help may help to not to loss my remote job.
Thank you..
BartoszP
Re: Nord VPN Disconnection problem with Mikrotik RB750 GR3 Router
Sat Dec 10, 2022 2:10 am
Maybe VPN supplier does disconnect too long sessions and your router does not get aware of this and keeps trying to send traffic over "semi-open" interface.
Write a script which would be disabling/disconnecting VPN tunnel and starting it every eg. 24 hours to refresh connection.
Users browsing this forum: complexxL9 and 44 guests
