mutluit
Forum Veteran
Forum Veteran
Enabling also IPv6 in RouterOS
Fri Dec 09, 2022 10:14 pm
on a MikroTik small router hAP ac^2 using RouterOS 6.47.10 that was long ago
configured for only IPv4 (ie. IPv6 was explicitly disabled), I now need to enable also IPv6.
Can someone please tell me where in RouterOS to start to make this change in the configuration?
Under /ipv6 there is nothing but 'export', ie. it's empty.
TIA
mozerd
Forum Veteran
Forum Veteran
Re: Enabling also IPv6 in RouterOS  [SOLVED]
Fri Dec 09, 2022 11:10 pm
Using Winbox Check under system/packages then you should see ipv6 … enable this then reboot …
mutluit
Forum Veteran
Forum Veteran
Fri Dec 09, 2022 11:21 pm
Thx, this worked, now having entries under /ipv6.
Users browsing this forum: No registered users and 91 guests
