Sat Dec 10, 2022 12:02 pm
Most ROS devices (unlike PCs) don't have real time clock. So when ROS boots it can't get (a good approximation of) correct local time from very start. It reverts to timestamp of certain files (which get updated frequently) meaning that after normal reboot time will be some 10s of seconds in the past. After netinstall this is not the case, so device will start with Unix time 0 (1st of January 1970 0:00:00 UTC). If actual time matters, external time source needs to be used (e.g. NTP time servers). It is important to understand that it takes some time (up to a few minutes) for NTP to do final adjustments of time and this is perfectly normal.
Linux keeps time in UTC internally, so do ROS devices, and formatting with local time is purely cosmetics of displaying time stamps.
As to the problems of adguard container starting: containers don't keep their time separately from host OS. If particular service is sensitive to clearly erroneous time stamps, then you have to delay start of such service until host system (router) has time issues solved. You can check if NTP server is content with own status by querying NTP server status.
BTW UTC 00:00 time is not the result of timezone problems, it's result of router not having slightest idea about actual time (as explained earlier). Some services (in general) sometimes play smart and complain if local time is behind timestamps of certain files. So it is important to have correct time every time (also while installing a container for example). I'm not saying adguard is one of these services, just mentioning that such problems exist.
