druneau
Add speaker to wap AC board?
Sat Dec 10, 2022 5:55 pm
I was wanting to use the buzzer on my wap AC, and that's when I learned it didn't have one.
I took a look at the board and there is a circular pad (see attached picture). I was wondering if anyone knows if the pad is for a speaker or, most probably for a capacitor?
If I had an osciloscope I would probably make it buzz and check signal... my multimeter seems too slow to catch anything.
Thanks in advance for any help on the matter.
rextended
Re: Add speaker to wap AC board?
Sat Dec 10, 2022 7:09 pm
C44
druneau
Sat Dec 10, 2022 7:42 pm
Thanks,
after posting i compared to other PCB's and understood more about nomenclature. So definately not a spot for a speaker!
Any idea if it's possible to add a buzzer to RouterBoard boards when there is no space on PCB? Is there a way to tap into GPIO's? or is that only for IoT boards.
Users browsing this forum: No registered users and 89 guests
