Hello all,
I have read dozens of topics and sites and found no solusion to my issue.
My setup is:
- RB4011IGS+RM
- 2x UAP-AC-Lite
- CSS326-24G-2S+RM
The issue: on iPhones (2 separate devices) from time to time internet is gone. like frozen for some time. Sometimes it get back after 1-2min sometimes I need to click on wifi to disconect and connect again - internet is back. What is important - at that moment the wifi works fine - for example I am able to reach my amplifi via IP address. Iphone shows that wifi connected but no wifi.
I started with UAP-AC-Lite - only 2,4ghz, then 5ghz, dozens of different options - nothing helped.
Then after realizing that wifi works (able to connect to other devices in home network by IP) I think it's more on router side then on access points.
When I catch the moment when there is no internet on router in ARP I cannot ping the device - packets are lost. And then after reseting wifi on phone - eveything ok again.
Happening on all iOS phones (XS, 14). On my son Android it seems to be ok.
LAN connection (via cable) - works all the time (laptop, PC)
Laptop on the same wifi - works fine with no stops.
Where should I look now... ? help me:)
