cysergtlo
Help... Setup NAT ON RB2011UiAS-2HnD Failed....
Sun Dec 11, 2022 11:02 am
Client Cant Ping To Internet or WAN
On Log its too much info about
srcnat: in:(unknown 0) out:ether2_WAN, src-mac.....
This my config source :
# model = RB2011UiAS-2HnD
add fast-forward=no mtu=1500 name=bridge1
set [ find default-name=ether1 ] name=ether1_WANBK
set [ find default-name=ether2 ] name=ether2_WAN rx-flow-control=auto tx-flow-control=auto
set [ find default-name=ether5 ] name=ether5_LAN rx-flow-control=auto tx-flow-control=auto
set [ find default-name=ether6 ] disabled=yes
set [ find default-name=ether7 ] disabled=yes
set [ find default-name=ether8 ] disabled=yes
set [ find default-name=ether9 ] disabled=yes
set [ find default-name=ether10 ] disabled=yes
set [ find default-name=sfp1 ] disabled=yes
/interface wireless
set [ find default-name=wlan1 ] country=indonesia2 disabled=no \
    frequency-mode=manual-txpower mode=ap-bridge ssid=PERBEND
set [ find default=yes ] authentication-types=wpa-psk,wpa2-psk mode= dynamic-keys wpa-pre-shared-key=........ wpa2-pre-shared-key=........
add name=dhcp_pool0 ranges=192.168.200.1-192.168.200.250
add address-pool=dhcp_pool0 bootp-support=none disabled=no interface=ether5_LAN lease-time=3d10m name=dhcp1
add bridge=bridge1 fast-leave=yes interface=ether1_WANBK point-to-point=no restricted-role=yes trusted=yes
add bridge=bridge1 fast-leave=yes interface=wlan1 point-to-point=no trusted=yes
/interface bridge settings
set use-ip-firewall=yes
/ip settings
set accept-redirects=yes accept-source-route=yes secure-redirects=no
add address=192.168.200.254/24 interface=ether5_LAN network=192.168.200.0
/ip dhcp-client
add add-default-route=no disabled=no interface=bridge1 use-peer-dns=no use-peer-ntp=no
add add-default-route=no disabled=no interface=ether2_WAN use-peer-dns=no use-peer-ntp=no
add address=192.168.200.0/24 dns-server=192.168.200.254 gateway=192.168.200.254 netmask=24 ntp-server=192.168.200.254
add address=192.168.222.0/24 dns-server=192.168.222.254 gateway=192.168.222.254 netmask=24 ntp-server=192.168.222.254
set allow-remote-requests=yes servers=172.25.5.1,192.168.30.1,8.8.8.8
add action=masquerade chain=srcnat log=yes out-interface=ether2_WAN
add distance=30 gateway=172.25.5.1
add disabled=yes distance=1 dst-address=10.10.0.0/16 gateway=172.25.5.1
add distance=1 dst-address=172.18.0.0/24 gateway=172.25.5.1
erlinden
Re: Help... Setup NAT ON RB2011UiAS-2HnD Failed....
Sun Dec 11, 2022 11:42 am
Mmmm...a lot of things not making sense:
  • where are your firewall filter rules?
  • why is there a DHCP client on the bridge?
  • what is the purpose of the 192.168.222.x network?
  • /ip dns has the 192.168.30.1 entry...are you behind NAT?
  • why the static routes?
  • less important...WPA-PSK? You can (nearly) leave the Wifi open
Maybe some additional info will give more insight on where you are using the RB and how.
cysergtlo
Sun Dec 11, 2022 12:07 pm
where are your firewall filter rules? i not setup any filter rules for now...
why is there a DHCP client on the bridge? I have 2 WAN Gateway ( Eth1 [192.168.30.1] and Eth2 [172.25.5.1] and both is DHCP so i make bridge to combine Wifi with Eth1 )
what is the purpose of the 192.168.222.x network? Sorry thats for my plan if Mikrotik wifi have DHCP Server
/ip dns has the 192.168.30.1 entry...are you behind NAT? yes
why the static routes? Cause I Have 2 Gateway thats for next plan to make Special Route Which i will manage it later after My Client can connect to internet
less important...WPA-PSK? You can (nearly) leave the Wifi open Noted
erlinden
Sun Dec 11, 2022 12:15 pm
May I suggest starting from scratch...getting everything in place correctly (not many interfaces on the bridge), and then reconfigure to multi WAN?
cysergtlo
Sun Dec 11, 2022 12:31 pm
Actualy My Wifi has problem too.. it always Italic text Interface Name even i was setup DHCP server for it..but if i combine with Bridge the problem was solved. But still client 192.168.200.0/24 always fail connect to internet. but Wifi Client 192.168.30.0/24 from bridge can Connect To Internet.
I do listing all my config to hope that maybe someone can correct the code that causes the NAT setting to fail
anav
Sun Dec 11, 2022 5:30 pm
What erlinden is saying is that nothing about your config is standard or default, you have funny settings that most dont use all over the place.
In other words start with the default settings see what works and then we can go from there to add functionality... If I get time I will post something you can use... busy at the moment
cysergtlo
Tue Dec 13, 2022 7:02 am
Problem was solved... ISP was block my nat using limit from TTL
Users browsing this forum: Bing [Bot], lurker888 and 53 guests
