dkriegner
safety concerns LHG 60G
Mon Dec 12, 2022 10:54 am
Dear mikrotik experts,
I would like to know how to read/understand the formulation in the FCC statement of the LHG 60G.
On page 5 of the manual https://i.mt.lv/cdn/product_files/LHG_60G_H_190848.pdf is stated that
95 cm minimum distance has to be maintained between the antenna and the occupational user/general public.
Under such configuration, the FCC radiation exposure limits set forth for an population/uncontrolled environment
can be satisfied.
Now the LHG 60G in an urban environment is often installed on house roof near a chimney. So once per year chimney maintenance might require someone to come close to the antenna for a limited amount of time.
Does this pose any problems?
kind regards
Dominik
normis
Re: safety concerns LHG 60G
Mon Dec 12, 2022 11:02 am
This refers to constant position and this text applies to all WIFI as well. It is a generic warning not to mount the antenna near your head, if you are working in that position for a long time (days, months).
There are no known health effects when installing or performing maintenance.
dkriegner
Mon Dec 12, 2022 11:52 am
Thank you for the quick reply. I am aware that a similar warning (just with a different distance) applies also e.g. for my notebook.
Users browsing this forum: lurker888 and 37 guests
