sunakashi
How upgrade container?
Mon Dec 12, 2022 3:57 pm
Please, how can I upgrade container, more specific pihole. I'm used to SSH, but I have no idea how to do it in RouterOS and I cannot find anything relevant to this topic. Thanks.
Shahid
Re: How upgrade container?
Mon Dec 12, 2022 10:08 pm
If it allows then backup your pihole settings, remove container & pull again then restore settings.
jvanhambelgium
Mon Dec 12, 2022 11:04 pm
If you made folder-mappings / mounts on the Pihole container pointing to some USB-storage for eg. /etc/pihole I would thing there is no need to export/restore the config as it is not deleted when you delete the Pihole-container ?
1) Stop the container
2) Delete the container
3) Pull newest instance with exactly the same settings (eg. mounts, vETH interface etc,etc)
4) Start container
Or is my logic flawed ? I do the same for a bunch of containers running on my Synology NAS. Every container should be stateless and all important data should be kept outside of it...
tangent
Tue Dec 13, 2022 3:35 am
Nope; it's precisely correct, often phrased as the "cattle vs pets" analogy. If you can't "slaughter" your cattle and bring new ones into their place without major disruption, you're doing something wrong.
Amm0
Tue Dec 13, 2022 6:07 am
Now that funny and 100% spot on.
And the say "curiosity killed the cat" too: so I wouldn't recommend trying "/container/reset 0 file=mycontainer.tar" to reload an image – as that borked a working image for me nor replace it. Had to slaughter that cow and/or bury the dead cat. Likely that cow is easily reincarnated using same file, envlist, mounts, & just like new.
sunakashi
Wed Dec 14, 2022 3:47 pm
Well... That is not very user friendly. I'll probably stick with RPi and SSH.
tangent
Wed Dec 14, 2022 4:11 pm
Containers are not VMs. Get your head around that, and you'll start to see why containerization is taking over the world.
Amm0
Wed Dec 14, 2022 4:12 pm
I think the point is generally with containers if you ever need to use SSH to change them, you may be doing something wrong. *unless your trying to develop/test a new Dockerfile or modify something that is a "mounted"... The key thing to understand is data/config and code are designed to be seperate, so it should be completely safe to just the replace the code part, while leaving the data/config part stays same.
In your case, you should be able to delete the existing container in /container, then just add another, picking the new PiHole image, use same envlist , same mounts, - it will pull a new one and use your same setting as before – since there stored separately e.g. mount and environment tabs. Mikrotik docs direct folk to setup PiHole up this way already with the config/data being seperate from image, so you should be set there. So it's really just "delete the container to upgrade" that needs to be added, then follow the same step for just creating the container you used originally (since you'd already created the envlist and mount the first time).
# find your pihole container's ID (generally 0) that you want to upgrade
/container/print
# remove container
/container/remove 0
# re-add same container
/container/add file=pihole.tar interface=veth1 envlist=pihole_envs mounts=dnsmasq_pihole,etc_pihole hostname=PiHole
But there isn't a "one button" (or command) way to pull a new image AFAIK. And if you did SSH into the box, and changed stuff outside the configured mounts, then YES those changes be lost. If you used mount and/or envlist, those are preserved even if the container gets delete. Thus the advice to always use environment variables to configure containers (or build your image on a PC using a customized Dockerfile as works). To @tagent's point, Mikrotiks are generally "pets" while containers should be the "cows".
If you like running PiHole on a seperate box, I can't argue that may be simplier. But the docker model may be worth thinking about, even how to upgrade isn't obvious at first.
tangent
Wed Dec 14, 2022 4:24 pm
It isn't necessarily so. Larger organizations will have an automated deployment process that takes a stock RouterOS box, upgrades it to some tested firmware release, maybe sets a skin, applies a configuration, tests it all, and shuts it down, ready for deployment.
Sound like containerization? It should, because it's part of the same movement, variously styled DevOps or Infrasructure as code. Hardware isn't as malleable as software, but at scale, you can bet all those CPEs and WISP tower radios aren't being treated as pets.
jvanhambelgium
Updated my Pi-hole yesterday on the RB5009 and 30seconds later it was already back up & running with all config (because stored outside the container-image)
Can't be more simpel then this...
Amm0
Wed Dec 14, 2022 4:46 pm
I 100% agree. More thinking the OP was trying to "upgrade PiHole", which does take a little container philosophy to understand. But II think the metaphor was getting lost - but not wrong.
tangent
Wed Dec 14, 2022 5:12 pm
Incidentally, this thread inspired me to come up with a better analogy.
Amm0
Wed Dec 14, 2022 6:06 pm
Not mix metaphors. But the "reincarnate" method is what's missing.
@jvanhambelgium points out isn't hard, just 4 steps. RouterOS ideally have some option that keeps setting, and reloads the image file (or pulls from registry) since that's what the OP was after, I think.
sunakashi
Sat Dec 17, 2022 1:34 pm
I would prefer to update simple by pressing a button in GUI, that's why more people prefer Adguard over pihole.
But with containers here it is a next step to learn. NextDNS alone makes sense even more.
Z0ltan
Sun Feb 19, 2023 12:08 pm
I have scripted it however the container status is always “error” after running the script. Issuing the same commands works.
/container/stop 0
:delay 20s;
/container/remove 0
/container/add remote-image=pihole/pihole:latest interface=veth1 root-dir=disk1/pihole mounts=dnsmasq_pihole,etc_pihole envlist=pihole_envs hostname=pihole start-on-boot=yes
:delay 60s;
/container/start 0
PeterXC
Fri Feb 24, 2023 11:24 pm
/container/stop 0
:delay 20s;
/container/remove 0
:delay 60s;
/container/start 0
I'd add logging=yes
In my case, 60s can be too short. Sometimes it extracts longer.
Keep in mind that starting 7.7 USB mount is not disk1 but usb1-part1
Strykar
Fri Mar 07, 2025 11:02 am
Since RoS (7.18.1) already knows the parameters a container was started with, adding an Update (to :latest) feature alongside Start and Stop container would be useful.
With multiple containers, search by repo name, and create a manually invoked script for each container.
# update_pihole.rsc
/container/stop [find where repo="registry-1.docker.io/pihole/pihole:latest"]
:delay 5
/container/remove [find where repo="registry-1.docker.io/pihole/pihole:latest"]
:delay 1
/container/add remote-image="pihole/pihole:latest" interface=veth1 envlist=pihole_envs root-dir=usb1/pihole mounts=dnsmasq_pihole,etc_pihole domain-name="my.home.lan" logging=yes start-on-boot=yes
:delay 90
/container/start [find where repo="registry-1.docker.io/pihole/pihole:latest"]
Adjust delays to suit your containers, pihole takes the longest to extract and come up of the few I tested.
Since RoS knows the container's exact state, it is best suited to add the update knob for lowest downtimes when upgrading sane containers that use envs or mounts.
List repo URLs for all containers:
:foreach i in=[/container/print as-value] do={ :if ($i->"repo"!="") do={ :put ($i->"repo") } }
registry-1.docker.io/netbirdio/netbird:latest
scddt
Fri Mar 07, 2025 4:17 pm
If it is helpful to someone, I currently use this script:
	/container;
	:local HN "{{.hostname}}";
	:local TAG "{{.TAG}}";
	:local FN "{{.TAR}}";
	:local START [/system/clock/get time];
	print where tag=$TAG;
	:while ([find where tag=$TAG status=running]) do={stop [find tag=$TAG status=running]; :delay 1;};
	:while ([find where tag=$TAG status=stopped]) do={remove [find tag=$TAG status=stopped]; :delay 1;};
	:while ([find where tag=$TAG]) do={:delay 0.1;};
	add file=$FN envlist={{.env}} hostname=$HN interface=v{{.env}} logging=yes start-on-boot=yes;
	:while ([:len [find where tag=$TAG]]=0) do={:delay 0.1;};
	start [find tag=$TAG];
	:while ([find where tag=$TAG status=stopped]) do={:delay 0.1;};
	:delay 1; # Delay to show startup logs.
	/log/print where time>$START topics=container,info,debug;
It would need to be adapted to add mounts, but I find it useful. It is part of a small go executable that establishes a single SSH connection, then first transfers the container image up (I'm building locally), then executes the script update. The while loops with delay checkings make it quick and dependable.
ssyur
Fri Mar 07, 2025 7:25 pm
i use this script for Adguard, it keeps all the settings & history
if history is not needed to be kept -> adguard_work mount is not needed
veth for container is set to 10.0.0.2
mounts :
set servers=1.1.1.1
/container/stop [find where comment~"adguard"]
:while ( [/container print count-only where comment~"adguard" status=stopping] > 0) do={ :delay 1 }
/container/remove [find where comment~"adguard"]
:delay 5
/container/add interface="adguard" remote-image="adguard/adguardhome:latest" mounts="adguard_conf,adguard_work" root-dir="usb1/apps/adguard/root" start-on-boot=yes logging=no comment="adguard"
:delay 3
:while ( [/container print count-only where comment~"adguard" status=extracting] > 0 ) do { :delay 1 }
/container/start [find where comment~"adguard"]
set servers=10.0.0.2
grzegorzb
Wed Mar 26, 2025 1:39 pm
The simplest way to perform an update is through Winbox in the "container" section, and then in CMD with the command "--update".
tangent
Wed Mar 26, 2025 3:18 pm
That's entirely contingent on what inside the container is responding to that flag.
If RouterOS ever gets a CoW/overlay image system, this method will have a further downside: it will balloon the on-disk size by adding another layer. (As it is, I believe RouterOS will just overwrite the older file versions.)
