mikrotiknetme
If host is up
Mon Dec 12, 2022 5:33 pm
I'm looking to write a script that checks to see if a host is up (as a boolean) so I can use it in an if statement.
I wrote this but not working :(
:if (string.find([/tool/ping address=192.168.0.5 count=1],"timeout") ) do={ :put "value is false" } else={ :put "value is true" }
:if (:find [/tool/ping address=192.168.0.5 count=1] "timeout" 0 ) do={ :put "value is false" } else={ :put "value is true" }
Also the scripts in netwatch (the 'test' script), are arguments passed into these at all?
rextended
Re: If host is up
Mon Dec 12, 2022 6:50 pm
if (write.at.random true) what do you expect?
:if ([:ping address=192.168.0.5 count=1] = 0) do={
    :put "reply NOT received"
} else={
    :put "reply received"
mikrotiknetme
Re: If host is up
Tue Dec 13, 2022 3:09 pm
Yes, I got the echos incorrect on my first post as I had copied it, but it still gave the same text if the host was up or down.
Unfortunately, the code you gave does not appear to work either.
[j@MikroTik] > /system script run script1
Columns: SEQ, HOST, SIZE, TTL, TIME
SEQ HOST SIZE TTL TIME
0 1.1.1.1 56 58 25ms735us
reply received
Columns: SEQ, HOST, STATUS
SEQ HOST STATUS
0 192.168.192.192 timeout
reply received
[j@MikroTik] >
rextended
Re: If host is up
Tue Dec 13, 2022 3:38 pm
Why not???
Nex time specify that you use RouterOS v6 or v7...
for v7:
:if ([:typeof ([:ping address=195.168.0.5 count=1 as-value]->"time")] = "nothing") do={
} else={
anav
Re: If host is up  [SOLVED]
Tue Dec 13, 2022 4:31 pm
for v7:
:if ([:typeof ([:ping address=shwing count=1 as-value]->"time")] = "nothing") do={
    :put "seed not received"
} else={
    :put "bun in the oven"
Fixed it for you, in the spirit of the title! :-)
rextended
Re: If host is up
Tue Dec 13, 2022 4:37 pm
:facepalm: :lol:
mikrotiknetme
Re: If host is up
Tue Dec 13, 2022 5:14 pm
Not sure I get your joke :D But thank you for the help
rextended
Re: If host is up
Tue Dec 13, 2022 5:41 pm
You really do not noticed that the @anav version is for joke and on my previous post is present the working version???
anav
Re: If host is up
Tue Dec 13, 2022 6:17 pm
I found it amusing, maybe the yolk is on you...... * as in an inseminated egg* lol..............
mikrotiknetme
Re: If host is up
Tue Dec 13, 2022 8:43 pm
Really sorry but I can't understand your broken English :D Thanks again for the help
Users browsing this forum: 0xAA55, pe1chl and 58 guests
