mktuser
CRS212 HW offload won´t work.
Tue Dec 13, 2022 4:16 pm
i setup CRS212 with SFP+ uplink. Link on SFP+ is ok, but if i enable HW offload, traffic can´t pass thru.
SFP+ is connected to SFP+ in CCR2116. Here is CFG of CRS212, hope someone will help.
[admin@crs212] > export hide-sensitive
# dec/13/2022 15:05:12 by RouterOS 7.6
# software id = 7E5F-J1M5
# model = CRS212-1G-10S-1S+
# serial number = 787807943E29
add mtu=1500 name=bridge1 protocol-mode=none
set [ find default-name=ether1 ] comment=slave speed=100Mbps
set [ find default-name=sfp1 ] advertise=10M-half,10M-full,100M-half,100M-full,1000M-half,1000M-full auto-negotiation=no comment=slave
set [ find default-name=sfp2 ] advertise=10M-half,10M-full,100M-half,100M-full,1000M-half,1000M-full auto-negotiation=no comment=slave
set [ find default-name=sfp3 ] advertise=10M-half,10M-full,100M-half,100M-full,1000M-half,1000M-full auto-negotiation=no comment=slave
set [ find default-name=sfp4 ] advertise=10M-half,10M-full,100M-half,100M-full,1000M-half,1000M-full auto-negotiation=no comment=slave rx-flow-control=auto \
    tx-flow-control=auto
set [ find default-name=sfp5 ] advertise=10M-half,10M-full,100M-half,100M-full,1000M-half,1000M-full auto-negotiation=no comment=slave
set [ find default-name=sfp6 ] advertise=10M-half,10M-full,100M-half,100M-full,1000M-half,1000M-full auto-negotiation=no comment=slave
set [ find default-name=sfp7 ] advertise=10M-half,10M-full,100M-half,100M-full,1000M-half,1000M-full auto-negotiation=no comment=slave
set [ find default-name=sfp8 ] advertise=10M-half,10M-full,100M-half,100M-full,1000M-half,1000M-full auto-negotiation=no comment=slave
set [ find default-name=sfp9 ] advertise=10M-half,10M-full,100M-half,100M-full,1000M-half,1000M-full auto-negotiation=no comment=slave
set [ find default-name=sfp10 ] advertise=10M-half,10M-full,100M-half,100M-full,1000M-half,1000M-full auto-negotiation=no comment=slave
set [ find default-name=sfpplus1 ] advertise=10M-half,10M-full,100M-half,100M-full,1000M-half,1000M-full auto-negotiation=no comment=slave
/interface lte apn
/port
set 0 name=serial0
/user group
add name=api policy=read,test,api,!local,!telnet,!ssh,!ftp,!reboot,!write,!policy,!winbox,!password,!web,!sniff,!sensitive,!romon,!rest-api
add name=technik policy=local,telnet,ftp,reboot,read,write,test,winbox,web,sniff,rest-api,!ssh,!policy,!password,!sensitive,!api,!romon
add bridge=bridge1 ingress-filtering=no interface=sfpplus1
add bridge=bridge1 ingress-filtering=no interface=sfp1
add bridge=bridge1 ingress-filtering=no interface=sfp2
add bridge=bridge1 ingress-filtering=no interface=sfp3
add bridge=bridge1 hw=no ingress-filtering=no interface=sfp4
add bridge=bridge1 ingress-filtering=no interface=sfp5
add bridge=bridge1 ingress-filtering=no interface=sfp6
add bridge=bridge1 ingress-filtering=no interface=sfp7
add bridge=bridge1 ingress-filtering=no interface=sfp8
add bridge=bridge1 interface=sfp9
add bridge=bridge1 interface=sfp10
/ip settings
set max-neighbor-entries=8192
/ipv6 settings
set 0 isolation-leakage-profile-override=1 qos-scheme-precedence=pcp-based,sa-based,da-based,dscp-based,protocol-based,vlan-based,pcp-based
set 1 isolation-leakage-profile-override=1 qos-scheme-precedence=pcp-based,sa-based,da-based,dscp-based,protocol-based,vlan-based,pcp-based
set 2 isolation-leakage-profile-override=1 qos-scheme-precedence=pcp-based,sa-based,da-based,dscp-based,protocol-based,vlan-based,pcp-based
set 3 isolation-leakage-profile-override=1 qos-scheme-precedence=pcp-based,sa-based,da-based,dscp-based,protocol-based,vlan-based,pcp-based
set 4 isolation-leakage-profile-override=1 qos-scheme-precedence=pcp-based,sa-based,da-based,dscp-based,protocol-based,vlan-based,pcp-based
set 5 isolation-leakage-profile-override=1 qos-scheme-precedence=pcp-based,sa-based,da-based,dscp-based,protocol-based,vlan-based,pcp-based
set 6 isolation-leakage-profile-override=1 qos-scheme-precedence=pcp-based,sa-based,da-based,dscp-based,protocol-based,vlan-based,pcp-based
set 7 isolation-leakage-profile-override=1 qos-scheme-precedence=pcp-based,sa-based,da-based,dscp-based,protocol-based,vlan-based,pcp-based
set 8 isolation-leakage-profile-override=1 qos-scheme-precedence=pcp-based,sa-based,da-based,dscp-based,protocol-based,vlan-based,pcp-based
set 9 isolation-leakage-profile-override=1 qos-scheme-precedence=pcp-based,sa-based,da-based,dscp-based,protocol-based,vlan-based,pcp-based
set 10 isolation-leakage-profile-override=1 qos-scheme-precedence=pcp-based,sa-based,da-based,dscp-based,protocol-based,vlan-based,pcp-based
set 11 isolation-leakage-profile-override=0 qos-scheme-precedence=pcp-based,sa-based,da-based,dscp-based,protocol-based,vlan-based,pcp-based
set 12 isolation-leakage-profile-override=0 qos-scheme-precedence=pcp-based,sa-based,da-based,dscp-based,protocol-based,vlan-based,pcp-based
/interface ethernet switch port-isolation
add port-profile=1 ports=ether1,switch1-cpu type=dst
/interface ovpn-server server
set auth=sha1,md5
/ip dhcp-client
add interface=bridge1
add comment="GW" disabled=no dst-address=0.0.0.0/0 gateway=10.240.1.1
/ip ssh
set allow-none-crypto=yes forwarding-enabled=remote
/lcd
set time-interval=daily
/system identity
set name=crs212
/system logging
add action=remote topics=error
add action=remote topics=account
/system ntp client
set enabled=yes
/system ntp client servers
add address=195.113.144.201
/system watchdog
set ping-start-after-boot=15m
/tool graphing
set store-every=hour
/tool graphing interface
add
/tool graphing resource
add
Now i need to disable HW offload on SFP4. When it on, data can´t pass and devices are not responding.
Users browsing this forum: No registered users and 15 guests
