menace
fetch url timeout
Wed Dec 14, 2022 12:23 am
on a Hap ac lite localtion A (V.6.49.7 stable)
when try to fetch a small PHP site from a webserver I get a timeout
when I try the same on a hap AC2 localtion B(V. 6.47.8 long-term)
i can fetch the site with no problem
when I try the same on a hap AC2 localtion C(V. 6.47 stable)
rextended
Re: fetch url timeout
Wed Dec 14, 2022 12:26 am
at this point go with Hap ac lite to location B or C and check.
"fetch a small PHP site from a webserver"
how much "small"?
Hap ac lite have only 16MiB disk and 64MB RAM and not all the time the free space is the same...
(hap ac2 has 16MiB of disk, but 128MB of RAM)
menace
Wed Dec 14, 2022 12:45 am
rextended > the file is 353 byte
rextended
Wed Dec 14, 2022 12:48 am
now is left to try device on site B or C...
menace
Wed Dec 14, 2022 3:49 pm
Just came to think of it I have another hap ac lite(V6.47 stabil) in the world(location D), and it can fetch the site with no problem
the AC lite runs default config with some minor changes (port kocking, ip adress, dhcp scope)
I dont see the problem in the config (included)
Users browsing this forum: aferreira and 118 guests
