moradikh1
script for number of session per user in ppp
Wed Dec 14, 2022 7:43 am
hi,
For one scenario, it is necessary for users to have only 3 sessions for each username to connect to the VPN. To solve this problem, I have used the script in the UP section of the profile, but the script does not work properly, please help.
:local allowed 3;
:local scount 0;
:local nama "$user";
:local sess [/ppp active find where name=$nama]
:local callerid [/ppp active get [find name=$nama] caller-id];
:log warning "PPP User ($nama) Logged in from $callerid ";
:foreach sessid in= $sess do={
:set scount ($scount + 1);
:if ($scount <= $allowed ) do={
:log warning "Session ($scount) find for User: ($nama) is ($sessid) Allowed!";
} else={
/ppp active remove [find session-id=$sessid];
:log error "Session ($scount) find for User: ($nama) is ($sessid) not Allowed and disconnected!";
Jotne
Re: script for number of session per user in ppp
Wed Dec 14, 2022 11:33 am
If you wrap you code in bracket { } and cut/paste to terminal, you would have see what was wrong.
For debugging in terminal change :log warning to :put to see the output
This line is missing a $
correct
:set $scount ($scount + 1)
No need for ; at end of each line, use tab in code and post it with code tags like this version that should work:
:local allowed 3
:local scount 0
:local nama "$user"
	} else={
Test version to debug in terminal. Change ass_test_user_name to a vpn user name
:local allowed 3
:local scount 0
:local nama "add_test_user_name"
:put "PPP User ($nama) Logged in from $callerid "
	:put "Session ($scount) find for User: ($nama) is ($sessid) Allowed!"
	} else={
#	/ppp active remove [find session-id=$sessid]
	:put "Session ($scount) find for User: ($nama) is ($sessid) not Allowed and disconnected!"
Edit
I see in ppp user session that you can set user login to only one or many. MT should add a number instead and you have not needed the script.
diamuxin
Wed Dec 14, 2022 12:17 pm
Hi @Jotne, @rextended,
What is the correct way to mofify the value of a variable?
In your example you put the following:
# This line is missing a $
# correct
However, Rex does not put it:
:if ([:len $searchresult] > 0) do={
        :set if [get $searchresult on-interface]
        :set outstring "For bridge host table the $activeMAC is coming from $if"
Let me know...
BR.
rextended
Wed Dec 14, 2022 12:19 pm
:global, :local and :set do not want $,
if you want "set" something inside array like :set ($array->"item") "value" apparently you must use $ in front of variable,
but really at that point the "name" of the variable is "passed" from the function (...) and you use the $ because the variable is inside the function (->)
I can make mistakes too, RouterOS is quite forgiving with syntax errors,
but then sometimes things don't work as expected anymore when they fix some problem, or whatever...
better to write immediately with the correct syntax...
some error check for understand
unusable debug code
# added path for avoid multiple time same string
    /ppp active
    :local allowed  3
    :local scount   0
# removed useless quotes
    :local nama     "$user"
    :local nama     $user
# removed path for avoid multiple time same string
    :local sess     [find where name=$nama]
# already $sess is [find where name=$nama], why call it again???
# (also missing where on previous line)
# not fixed now: this line potentially can do error if is present more than one ppp session with same name
    :local callerid [get [/ppp active find name=$nama] caller-id]
    :local callerid [get $sess caller-id]
# removed useless end space
    :log warning "PPP User ($nama) Logged in from $callerid"
# removed big error: space between = and variable
    :foreach sessid in=$sess do={
# after :set, $ must not be used
# noerror: or put a space on both sides, or not on both sides.
        :if ($scount <= $allowed) do={
    } else={
# added missing where
        remove [find where session-id=$sessid]
Jotne
Thu Dec 15, 2022 2:00 pm
Heads up for the learning tutorial. 👍
diamuxin
Thu Dec 15, 2022 2:06 pm
Good explanation!
BR.
rextended
Re: script for number of session per user in ppp  [SOLVED]
Thu Dec 15, 2022 2:53 pm
Another free lesson about bug on script parser:
this do not work.... as expected... (the comment say where for RouterOS is the error)
:local test do={:return $1}
:put "Hi!\r\nHi!"
:put [$test "Hi!\r\nHi!"]
# syntax error (line 4 column 20)
Solution: use ( ) !!!
:put "Hi!\r\nHi!"
:put [$test ("Hi!\r\nHi!")]
can also be solved on this way, but on this mode do not evidence script parser errors...
:local t2 "Hi!\r\nHi!"
:put $t2
:put [$test $t2]
moradikh1
Tue Dec 20, 2022 7:48 am
correct
:local allowed 3
:local scount 0
:local nama "$user"
	} else={
:local allowed 3
:local scount 0
	} else={
Edit
Thank you for your reply and for pointing out the coding errors
Yes, only one session is possible, but for more than this, for example, 3 sessions, it is not possible. If there is, I did not find it.
moradikh1
Tue Dec 20, 2022 7:50 am
:put "Hi!\r\nHi!"
Soluction: use ( ) !!!
:put "Hi!\r\nHi!"
:put $t2
:put [$test $t2]
Thanks for your advice
With a few corrections and changes, the problem was solved and the code works properly
moradikh1
Tue Dec 20, 2022 7:54 am
/ppp active
:local allowed 3
:local scount 0
:local nama $user
	:local sid [get $sessid session-id]
	:set scount ($scount+1)
	:if ($scount<=$allowed ) do={
		:log warning "Session #$scount  for User: ($nama) & SessionID: #$sid Allowed!"
	} else={
		:log error "Session #$scount  for User: ($nama) & SessionID: #$sid not Allowed and disconnected!"
		remove [find where session-id=[get $sessid session-id]]
I put the final code here for others to use
Users browsing this forum: Amazon [Bot] and 59 guests
