x00
LtAP mini and LHGG lte board serial number
Wed Dec 14, 2022 8:36 am
With which CLI command could I get the serial number of the LTE card in the LtAP mini and LHGG devices?
 /interface lte info lte1
CLI command doesn't give this information.
krafg
Re: LtAP mini and LHGG lte board serial number
Thu Dec 15, 2022 1:47 am
System -> resources -> USB
x00
Thu Dec 15, 2022 9:05 am
Thank you for your answer, but that's not what I want.
This is the result your command:
/system resource usb> print
 # DEVICE VENDOR                   NAME                  SPEED
 0 1-0    Linux 3.3.5 ehci_hcd     RB400 EHCI            480
 1 1-1    MikroTik                 R11e-LTE              480
I would need the serial number of the LTE module
krafg
Fri Dec 16, 2022 11:54 pm
Print detailed
/system resource usb print detail
Regards.
x00
Sat Dec 17, 2022 8:41 am
Print detailed
Regards.
Thanks, I'll try it next week.
x00
Mon Dec 19, 2022 8:01 am
Print detailed
Regards.
Unfortunately this command also can't show the real serial numbers... :(
 0 device="1-0" vendor="Linux 3.3.5 ehci_hcd" name="RB400 EHCI"
   serial-number="rb400_usb" vendor-id="0x1d6b" device-id="0x0002"
   speed="480" ports=1 usb-version=" 2.00"
 1 device="1-1" vendor="MikroTik" name="R11e-LTE" serial-number="000000000000"
   vendor-id="0x2cd2" device-id="0x0001" speed="480" usb-version=" 2.00"
krafg
Tue Dec 20, 2022 7:32 pm
Probably you need open a ticket on official Mikrotik support. Most probably is a RouterOS bug.
Regards.
Amm0
Tue Dec 20, 2022 7:54 pm
Have you tried upgrading the firmware on the modem (in the LTE interface)? Does it have a valid IMEI number in the LTE interface?
I recall see 0000 when the firmware upgrade fails on some of the r11e-LTE things... So a support ticket seem reasonable, just make sure to generate a supout.rif and provide that when you open a ticket.
Users browsing this forum: 4l4R1 and 27 guests
