tomoo
Help from version 6.92 to version 7 of IBGP
Wed Dec 14, 2022 1:58 pm
hello, please help, i can't change the version (6.492)
(Regulation) I CCR1036-12G-4S for the new device CCR2116-12G-4S+ 7.15
/routing filter add action=accept chain=IN-iBGP1 comment="KAT 205 Slave" prefix=0.0.0.0/0 prefix-length=0 set-bgp-local-pref=300 set-distance=205
/routing filter add action=accept chain=IN-iBGP1 comment="KAT 190 MASTER" disabled=yes prefix=0.0.0.0/0 prefix-length=0 set-bgp-local-pref=400 set-distance=190
/routing filter add action=reject string=IN-iBGP1
/routing filter add action=discard chain=OUT-iBGP1 prefix in ipaddress -ip address prefix-length=30-32
/routing filter add action=accept chain=OUT-iBGP1 prefix=ipaddress.0/24 prefix-length=32
/routing filter add action=reject string=OUT-iBGP1
/routing filter add action=accept chain=IN-iBGP2 comment="WAR 205 Slave" disabled=yes prefix=0.0.0.0/0 prefix-length=0 set-bgp-local-pref=300 set-distance=205
/routing filter add action=accept chain=IN-iBGP2 comment="WAR 190 MASTER" prefix=0.0.0.0/0 prefix-length=0 set-bgp-local-pref=400 set-distance=190
/routing filter add action=reject string=IN-iBGP2
/routing filter add action=discard chain=OUT-iBGP2 prefix=ipaddress-ipaddress prefix-length=30-32
/routing filter add action=accept chain=OUT-iBGP2 prefix=ipaddress prefix-length=30-32
/routing filter add action=accept chain=OUT-iBGP2 prefix=ipaddress prefix-length=32
/routing filter add action=accept chain=IN-IBGP-NAT prefix=10.0.0.0/8 prefix-length=8-32
/routing filter add action=accept chain=IN-IBGP-NAT prefix=100.64.0.0/10 prefix-length=10-32
/routing filter add action=accept chain=IN-IBGP-NAT prefix=172.16.0.0/12 prefix-length=12-32
/routing filter add action=accept chain=IN-IBGP-NAT prefix=192.168.0.0/16 prefix-length=16-32
/routing filter add action=discard chain=IN-IBGP-NAT
/routing filter add action=accept chain=OUT-IBGP-NAT prefix=10.0.0.0/8 prefix-length=8-32
/routing filter add action=accept chain=OUT-IBGP-NAT prefix=100.64.0.0/10 prefix-length=10-32
/routing filter add action=accept chain=OUT-IBGP-NAT prefix=172.16.0.0/12 prefix-length=12-32
/routing filter add action=accept chain=OUT-IBGP-NAT prefix=192.168.0.0/16 prefix-length=16-32
/routing filter add action=discard chain=OUT-IBGP-NAT
rextended
Re: Help from version 6.92 to version 7 of IBGP
Wed Dec 14, 2022 2:27 pm
update the new device to 7.6, has hundred of fix
Use a dummy device with 6.49.2, apply the bgp, routing filers and all the frills for BGP from CCR1036, upgrade the dummy device to 7.6 and you have all configuration updated to 7.6.
Export the config from the dummy device and apply it to the new CCR2116
(do not risk the direct upgrade of the CCR1036.......................)
tomoo
Wed Dec 14, 2022 3:27 pm
thanks, it works
Users browsing this forum: No registered users and 29 guests
