redrac
Need help to setup my switch [CRS226]
Thu Dec 15, 2022 10:28 am
Guys, Need helpppp
I'm going to setup my CRS226-24G as a layer2 swtich.
I need ether2-ether10 ports act as access port in vlan 10, and ether11-ether20 ports act as access port in vlan 100.
No need for trunk.
I'v tried create 2 bridges with vlan 10 and 100, but not work.
Hominidae
Re: Need help to setup my switch [CRS226]
Thu Dec 15, 2022 10:33 am
....read this first, since your switch is a CRS model and you are already trying to use ROS, instead of SwOS: viewtopic.php?f=13&t=143620
redrac
Thu Dec 15, 2022 12:30 pm
My ros version is routeros 6.47.3..but how?
redrac
Thu Dec 15, 2022 12:43 pm
I followed this thread :viewtopic.php?t=143620#p707001, finally, in the same vlan, PC can get an IP from dhcp server, wireless router wan connected to this vlan not get an IP...
erlinden
Thu Dec 15, 2022 2:20 pm
Can you please share your current configuration?
/export hide-sensitive file=anynameyoulike
Make sure to remove any personal information.
mkx
Thu Dec 15, 2022 2:23 pm
Actually guide by @pcunite doesn't apply to CRS226 very well. The reason is that this device can't offload VLAN-enabled bridge to hardware and you'd end up with poorly performing switch (far from wire-speed). So you better go with help pages for 2xx series switches, "port based VLAN" section is quite probably the right one.
Users browsing this forum: Buckeye, fobo, massinia and 10 guests
