Hello everybody,
this is my first post in this forum. Also I'm new to MT too.
Please excuse my horrible english skills.
I need help to configure a "CRS326-24G-2S+" with V-Lan.
The CRS326 should communicate over sfp2 wit an "Unifi Aggregation Switch Pro" on Port 19.
I would like to create 3 V-Lan on those ports:
V-Lan-ID 10 > 192.168.100.XXX > Port 17 - 22 > Untagged
V-Lan-ID 30 > 192.168.095.XXX > Port 09 - 16 > Untagged
V-Lan-ID 50 > 192.168.050.XXX > Port 01 - 08 > Untagged
sfp1: BACKUP Uplink to "Unifi" (Cold-Standby)
sfp2: Uplink to "Unifi"
The MT needs no static IP, because it's a test switch laying on my benchdesk.
If a device get connected on port 01 - 22 it should get an ip-adress via dhcp.
Informations:
The MT is powered by RouterOS 6.49.7
On the Unifi Port19 is configured as Uplink. The same configuration as on port19, connects various servers and HPE Aruba 1930 switches, with the same V-Lan ID's with the usw-pro-aggregation.
They work all. So it can only be the configuration on the CRS326.
I tried various configurations but nothing seems to work. I followed exactly the new configuration guide on this website. (switch.rsc | viewtopic.php?t=143620)
See my latest config (CRS326-config.txt) attched on the thread.
I beg you to help me configure this switch, before i get insane after two months of hopeless configuration.
