David1234
search with "~" on C# API?
Thu Dec 15, 2022 4:34 pm
up until now I have used this commands to find device on my router
 mikrotik.Send("/ppp/secret/print");
 mikrotik.Send("?name=" + device);
 mikrotik.Send("=.proplist=name,remote-address,last-logged-out", true);
I know from the cli I can use the "~" operator to search part of a name
for example
/ppp secret print where name ~"5808"
can I make the same command in the API?
I have try to change the "=" to "~" - but I got empty result
did I miss something ? or it's not doable ?
Thanks ,
mrz
Re: search with "~" on C# API?
Thu Dec 15, 2022 4:41 pm
you can't
David1234
Thu Dec 15, 2022 4:44 pm
Thanks ,
Users browsing this forum: No registered users and 76 guests
