MUM Europe 2020
jo2jo
Forum Veteran
Forum Veteran
change the port that the MT email TOOL uses
Mon Oct 15, 2007 7:32 am
how do you change the port that the email server uses?
since so many isps block port 25 i know you can do this on MT...just how?
this does NOT work:
/tool e-mail send to=blah@blah.com server="209.138.93.102:2525" from="jdfo@cdoxddf.net" subject="PUBLIC user login" body="your netwatch checked ip here"
tks
:beep :beep :beep
changeip
Re: change the port that the MT email TOOL uses
Mon Oct 15, 2007 8:13 am
possibly you can use the src-nat function ?
Colo and Wholesale Bandwidth Available! Sales at SanDiegoBroadband dot com
Chupaka
Mon Oct 15, 2007 3:33 pm
mmm... dst-nat =) use your MT server as mail server and dst-nat port 25 on your MT to any port on any server
Russian-speaking forum: https://forum.mikrotik.by/. Welcome!
For every complex problem, there is a solution that is simple, neat, and wrong.
MikroTik. Your life. Your routing.
sergejs
Mon Oct 15, 2007 4:55 pm
DST-NAT is not applied to the packets, that are sent by the router itself.
Chupaka
Tue Oct 16, 2007 12:41 am
so... you have to use 2 MTs in pair =) as we can see, paired MTs work wonders =)
Znuff
Tue Oct 16, 2007 1:26 am
Erm... Port 25 is the standard email port. There's no reason to change that... Instead MT RouterOS should support SMTPS for ISPs that block that port.
Chupaka
Tue Oct 16, 2007 2:34 am
the reason is that you need it here and now, and you cannot wait until ROS would support smtps
GotNet
Tue Oct 16, 2007 3:07 am
Outbound block? Use the ISPs SMTP.
Chupaka
Tue Oct 16, 2007 3:57 am
what if ISP does not have any, or its service is paid?
Users browsing this forum: AUsquirrel, bpwl, Guntis, Jusufs and 59 guests
