If you knew what mattered here, you’d have the problem solved already. How about you take a step back and accept that you’re here for another perspective. If I ask you for something you didn’t think to provide, that’s your alternative perspective, right there.
Ok, I can accept that.
I have a OPNsense Firewall it goes to a Engenius 8 port 2.5gig poe switch with 4 sfp+ ports, Port 8 is the uplink from my OPNSense firewall.
Port 12 SFP+ on the Engenius switch goes to my Microtik CRS309 port 8, My desktop is plugged into port 7 with a 10g SFP+ Fibre adapter that runs over to a intel nic.
Port 6 is going to my Unifi Edge switch 48 port with a Unifi Dac cable. I have Tried the Cisco Dac cable unifi Dac cable 10gtek Dac cable & a tenfour optics SFP= Optical transcevier.
ALL the DACS & optic receiver act the same, If i plug them in, nothing lights up or shows in the gui. If i reboot the switch they all work. If i unplug the DAC or Optical transceiver they don't come back on line till rebooting the switch.
Im running switch os 2.13.
Happy now
![Smile :)](./images/smilies/icon_smile.gif)
