eisa
Config migration from RB2011 to RB4011
Mon Dec 19, 2022 4:34 pm
I have <mikrotik rb2011uias-2hnd-in> and I bought <RB4011iGS+RM>.
They have same ports(10 RJ45 ports + 1 sfp port).
But <mikrotik rb2011uias-2hnd-in> has <Wi-Fi> and <LCD> function and I don't use it.
And <RB4011iGS+RM> has no <Wi-Fi> and <LCD> function.
I want to migrate my old RB2011 configuration to new RB4011 and I have two questions.
Q1) The configuration file of RB2011 can work properly with RB4011 ?
Q2) If the configuration of RB2011 is compatible with RB4011, The <Wi-Fi> and <LCD> function of RB2011 does not affect the RB4011?
Thank you for reading.
If you have any idea or experience, let me know it please.
Sincerely.
rextended
Re: Config migration from RB2011 to RB4011  [SOLVED]
Mon Dec 19, 2022 4:44 pm
The SFP is not the same, probably the RB4011 have the sfp1 interface named sfp-sfpplus1
You can EXPORT the config from first, searc all sfp1 occurrencies and replace it with sfp-sfpplus1 (check the name).
Search also all "MAC" occurrencies, and check that aren't any.
At that point you can paste inside 4011 terminal ignoring wlan and lcd errors.
erlinden
Mon Dec 19, 2022 4:49 pm
After exporting your current configuration, you can easily edit it in any text editor. You have to change it manually, otherwise the import will fail.
Also, if you have fixed MAC addresses, you have to change them.
And make sure that you are running the same RouterOS.
Do you have (many) users configured? Because that is (one of the items that is) missing in the export.
[Update] @anav: won't the import crash with incorrect values?
rextended
Mon Dec 19, 2022 4:55 pm
Wrong topic????
If the .rsc is pasted on the terminal it doesn't "crash"...
It just highlights the errors, but it continues.
Just simply ignore all errors on wireless/wlan/lcd.
erlinden
Mon Dec 19, 2022 5:49 pm
Learned something again today!
pe1chl
Mon Dec 19, 2022 7:01 pm
Also note that on the 2011 the WLAN interface is 2GHz and is called wlan1, while on the 4011 you have 2 WLAN interfaces, wlan1 is 5 GHz and wlan2 is 2 GHz.
So to migrate your 2 GHz config from 2011 to 4011 you need to edit all wlan1 in your export to wlan2.
But you have a RM version so that does not apply in this case (I mention it for others only).
I have been able to migrate my 2011 config to my 4011 this way, but in general I would advise against it.
It is better to export the config and keep it as notes, then start your 4011 from scratch.
Update the software to the version you want to use, THEN reset it to defaults (AFTER the update and reboot), and work from there.
Do only the config you see in your export, but not e.g. the firewall. Leave that as default and only add any rules you are sure that you need.
Other config can be copied/pasted when it is a lot of typing work and you know it is safe to do.
eisa
Wed Dec 28, 2022 12:10 am
You helped me a lot and I can do it without mistake.
Thank you really much.
Sincerely,
June.
eisa
Wed Dec 28, 2022 12:11 am
I can do it by myselp and your advice helped me.
Thank you so much.
Sincerely,
June.
eisa
Wed Dec 28, 2022 12:14 am
Wrong topic????
Thank you for your advice.
I've never met errors thanks to experts help.
Have a nice year end.
Thank you for kind reply.
Sincerely,
Junseok
eisa
Wed Dec 28, 2022 12:16 am
Thank you for your kind answer.
I can do it without any mistake for your answers.
Thank you so much.
Sincerely,
Junseok
Users browsing this forum: BioRobot, complexxL9 and 58 guests
