Rox169
HAP AX2 POE to HAP AX2 only 100Mbit
Mon Dec 19, 2022 10:16 pm
I have two HAP AX2. One HAP AX2 is powering another HAP AX2 both on ether1. There is autonegotiation set on on both but I can get only 100Mbit Could anyone please check if this is ROS problem or I have faulty unit?
Thank you
Amm0
Re: HAP AX2 POE to HAP AX2 only 100Mbit
Mon Dec 19, 2022 10:50 pm
A poor quality (or too long) cable would cause this... As would use an older PoE injector, are you using the PoE injector it came with?
Rox169
Mon Dec 19, 2022 11:42 pm
No Im using HAP AX2 as poe injector. But after few times I unplged and pluged cable it is ok for now...I have 1GB conection...
gigabyte091
Wed Feb 08, 2023 5:10 pm
Same thing, one of the ax2 autonegotiated 100mbps with outdoor antenna, also ax2 provided power to the device (ac3 always autonegotiated 1 Gbps), after netinstall that part is working, for now at least
Second ax2 always autonegotiated 100Mbps on ether2 with same device over same cable while other ports negotiated 1Gbps. That ax2 was RMA to supplier.
msokaczd
Thu Feb 09, 2023 8:51 am
Ita the poor cable, had same problem, when I connect devices its 1gbs, but after some time drop to 100mbs. Probably cable is near power cable and pick up electrical interferences. After replacing cable eith sftp cat6, never had problem again
hecatae
Thu Feb 09, 2023 2:50 pm
Chateau 5G ax is also have ethernet issues, this is looking like a hardware issue for the IPQ-6010
Rox169
Thu Feb 09, 2023 4:38 pm
I had the same probloem. HaP AC3 powered AX2 thorough cable and autonegotiation was only 100Mb. After a while it fixed itself...
gigabyte091
Wed Feb 22, 2023 8:22 pm
Soooo.... One router is at service.... So as my ax3 arrived i set it up as main router, downstairs ax2 is now AP/switch and I have RB260in between as i have another room with two additional links.
And trunk is coming into port 1 on RB260, leaving from port 2 to ax2, and i have VLAN88 going to another room upstairs. And guess what... Link speed between ax3 and rb260, 1000 Mbps, link speed between rb260 and ax2 100 !!!!!!!
Moments before, while i was still configuring rb260, i had 1000 mbps link speed between rb260 and my laptop on the same wire that is used as trunk to ax2 and now that same link is 100 Mbps...
Is this some sort of bug or something... this is second ax2 that have same problem...
Users browsing this forum: Bing [Bot], DanMos79, jaclaz and 19 guests
