Hossam81
Need to know MikroTik cap xl ac Coverage Range
Wed Dec 21, 2022 4:10 pm
Hello Everyone, I hope you can help me in this inquiry, as i'm installing 8 MikroTik cap xl ac Access points in our office & I need to know the coverage range in meters to make sure that i am able to cover the whole floor with the best possible signal quality, the are all installed on the ceiling & i need to know the coverage diameter for it, thanks in advance.
BartoszP
Re: Need to know MikroTik cap xl ac Coverage Range
Thu Dec 22, 2022 8:25 am
I always plan mounting AP that way that from each point in the office you "talk to" at least two of them.
If one goes down, the second could take over clients.
erlinden
Thu Dec 22, 2022 11:42 am
How did you get to the number 8?
Is there always a line of sight?
What are the requirements?
Ca6ko
Long time Member
Long time Member
Thu Dec 22, 2022 3:18 pm
The problem is upside down again.
First they calculate approximately the number of points and locations on the building plan. Then they do a radio survey with the temporary installation of points, make adjustments. Then the required number of points is calculated and purchased. Then they install them again, do the radio survey and make corrections if necessary. Then test operation and corrections are made again. It goes something like this
anav
Thu Dec 22, 2022 6:18 pm
More detail is required, a layout needs to be provided, shape height of ceiling, and knowledge of obstacles and walls etc........
Site survey is bang on. Get an AP hang it from the ceiling and start walking.
Good advice on having some overlap in case one goes down for some reason.
gotsprings
Thu Dec 22, 2022 11:22 pm
You disappoint me.
https://i.ebayimg.com/images/g/CA8AAOSw ... -l1600.jpg
Hossam81
Mon Dec 26, 2022 1:18 pm
Hello Everyone, i'd like to thank you for your replies & support, i have attached here the Layout & some pics of the already installed Access points for your advice, simply i need to know the coverage diameter in square meters, or something, so i can be sure that the whole floor is properly covered.
Please note that there was no Radio Survey done, the placement of the Access points was as shown in the attached photo (highlighted in yellow marks in the layout photo), thanks again.
https://ibb.co/3TjWDm8
https://ibb.co/M8srGXW
https://ibb.co/p2jbTJp
https://ibb.co/CvjvmRs
Users browsing this forum: Amazon [Bot] and 72 guests
