ccbb
Mikrotik CCR2004-1G-12S+2X's container
Thu Dec 22, 2022 4:15 pm
Mikrotik CCR2004-1G-12S+2X's rom is too small, only 128M, but it has 4G RAM, so it has set ramdisk=1G, but the openwrt image in the container cannot run. After running, it is stopped immediately. What's the reason?
sirbryan
Re: Mikrotik CCR2004-1G-12S+2X's container
Thu Dec 22, 2022 4:50 pm
Do you have logging enabled? What does that say?
ccbb
logging=yes Re: Mikrotik CCR2004-1G-12S+2X's container
Fri Dec 23, 2022 12:45 pm
logging=yes
/system/device-mode/update container=yes
/disk add type=tmpfs tmpfs-max-size=1000M slot=RAM
/container/config/set registry-url=https://registry-1.docker.io tmpdir=RAM
/interface/veth/add name=veth1 address=172.17.0.2/16 gateway=172.17.0.1
/interface/bridge/add name=dockers
/ip/address/add address=172.17.0.1/16 interface=dockers
/interface/bridge/port add bridge=dockers interface=veth1
/ip/firewall/nat/add chain=srcnat action=masquerade src-address=172.17.0.0/16
/container/envs/add env_list=linux_envs key=PASSWD value="letmein"
/container/mounts/add name=linux_data src=RAM/docker/linux_data dst=/data
add remote-image=unifreq/openwrt-aarch64:latest interface=veth1 envlist=linux_envs root-dir=RAM/docker/linux_root mounts=linux_data hostname=openwrt
ccbb
Fri Dec 23, 2022 1:02 pm
about logging file
getting layer sha256:a78819ced238e05f3cc7811c2f5c370be2125586cdf224ac204293083f7bc4da
layer sha256:a78819ced238e05f3cc7811c2f5c370be2125586cdf224ac204293083f7bc4da downloaded
import successful, container 2f370818-f547-404b-89b5-e65c453199b7
antonsb
Fri Dec 23, 2022 2:54 pm
You can use armvirt target -
docker import https://downloads.openwrt.org/snapshots/targets/armvirt/64/openwrt-armvirt-64-default-rootfs.tar.gz openwrt-arm64
docker save openwrt-arm64 > openwrt_arm64.tar
ccbb
Still not, as before
Fri Dec 23, 2022 8:30 pm
docker import https://downloads.openwrt.org/snapshots ... tfs.tar.gz openwrt-arm64
sirbryan
Fri Dec 23, 2022 10:14 pm
I set "CMD" to
 cmd="/bin/sh -c \"while ((true)); do sleep 1; done\""
then connect to the console (
/container; shell 0
or whatever # the container is) and poke around. For some containers, I figure out that there's a permissions problem, or some app is missing a library, or it can't find a file it's looking for.
sirbryan
Sat Dec 24, 2022 12:01 am
I've tried it on the same exact setup and I, too, can't keep the container running. I'll have to test on another machine without a RAM disk and on 7.6.
antonsb
Tue Dec 27, 2022 5:01 pm
Thanks, I managed to repeat this issue. This was broken somewhere from stable 7.6 to rc, release.
You can use 7.6 for now, as bare Openwrt uses only 8.8MB on arm64 systems
/ # cat /etc/banner
  _______                     ________        __
 |       |.-----.-----.-----.|  |  |  |.----.|  |_
 |   -   ||  _  |  -__|     ||  |  |  ||   _||   _|
 |_______||   __|_____|__|__||________||__|  |____|
          |__| W I R E L E S S   F R E E D O M
 OpenWrt SNAPSHOT, r21603-fb15cb4ce9
sirbryan
Wed Dec 28, 2022 7:11 am
So what exactly is broken? Use of the RAM disk for container storage?
antonsb
Wed Dec 28, 2022 11:06 am
In this case, cause is not related to tmpfs
sirbryan
Wed Dec 28, 2022 8:16 pm
Nice.
Downgraded my router to 7.6, then got the container working. Snapshot versions don't have a GUI, so this is what I ended up preparing for the router.
docker import https://downloads.openwrt.org/releases/22.03.2/targets/armvirt/64/openwrt-22.03.2-armvirt-64-default-rootfs.tar.gz openwrt-arm64
And with that, we have a GUI:
elico
Tue Jan 10, 2023 4:37 am
Downgraded from 7.7 to 7.6?
Nice.
sirbryan
Tue Jan 10, 2023 6:51 am
Yeah. I had upgraded to 7.7 to try the RAM disk. Switched back to 7.6 and just used the NAND.
AresPo
Sat May 06, 2023 8:35 pm
Nice.
Hello
Is it possible for you to fully explain the installation method? I did the settings according to the official Mikrotik videos on YouTube and followed your instructions on both 7.9 and 7.6 but still got the error that it wouldn't run.
update:
My router model is ax3 and it seems that none of the branches are working at the moment! (armvirt)
vuducdong
Sun Oct 08, 2023 11:26 am
Nice.
Please give complete instructions to install openwrt container. Thanks!
Users browsing this forum: No registered users and 0 guests
