jrprince
Routing Valid IP with CHR AWS to local servers
Thu Dec 22, 2022 6:36 pm
I have a local backup and disaster recovery network, however, it needs to be accessed through AWS IP's.
I need to add new interfaces and public IP's in the CHR and make these IP's redirected to my local network.
It is possible?
1. I can't enable two addresses in the CHR and make them work simultaneously. I enable the IPs on the interface, I connect the interface, another interface appears, I enable the DHCP Client and I get the internal IP. But it does not work.
2. With the IP that is in the CHR, even needing more, I try to configure the redirection and it doesn't work. Has anyone tried?
Here is the network design:
AWS: 172.10.58.1 (54.25.14.54 Ip valid) Ether 1 CHR Mikrotik.
MY LOCAL: 164.21.25.41 Ip válid
AWS <10.0.0.1/30 -- L2TP TUNNEL --- 10.0.0.2/30 > My LOCAL (MY LOCAL NETWORK 192.168.0.1/24)
a) Add CHR AWS route 192.168.0.0/24 to gateway 10.0.0.2
b) I configure firewall CHR AWS (all conection TCP port 80, redirect to 192.168.0.57:80)
c) CHR ping MY LOCAL and My Local network. All pings and routes ok!
d) When I run tests, it doesn't work.
I need to make valid AWS IP's run on my local network. By any means.
Has anyone done this?
Thank you all.
Users browsing this forum: No registered users and 41 guests
