klimadron
Mikrotik Switch with multiple ISP above router
Thu Dec 22, 2022 9:11 pm
Hi i have multiple fiber optic ISP and current router CCR1036-12G-4S lacks SFP ports
I want to put CRS310-1G-5S-4S+IN switch above it. So is this setup would work?:
3-4 fiber ISP -->CRS310-1G-5S-4S+IN ---> 1 SFP port to ---> CCR1036-12G-4S as main gateway,firewall,dhcp,nat,VPN ---> Local networks
Only 1 ISP will work at the same time, the rest are for redundcy. I don't want to use switch as a main router.
And for example if there is VPN server on the router my public IP address will bind to the switch or router? Will i need to configure something or i can just use 1 bridge and disable SFP ports with ISPs i dont want to use?
pcunite
Re: Mikrotik Switch with multiple ISP above router
Thu Dec 29, 2022 4:09 pm
Yes
Users browsing this forum: Irish9 and 90 guests
