sogware
Chained VLAN
Fri Dec 23, 2022 12:03 am
Hello all,
I've done some simple RouterOS configurations until now, but the following is a little above my head.
I need to provide internet access to a third person who has his own hardware (Generic AP in the picture). I have an hAP AC2 connected to the internet via a bridged modem.
Because of physical limitations I need to connect the 3rd person AP via a wAP AC2.
My (limited) knowledge tells me this should be possible, but VLANs always makes me confused.
I couldn't find a setup like this in the forum or on the internet, so any help on how to tackle this problem is really appreciated!
Thanks in advance!
Paul
anav
Re: Chained VLAN
Fri Dec 23, 2022 4:41 pm
post your hapac and wapac settings.
/export file=anynameyouwish ( minus MT serial numbers and any public WANIP information )
sogware
Re: Chained VLAN
Tue Dec 27, 2022 11:39 am
Hi Anav,
Sorry for the late reply (something to do with Christmas and stuff).
This is my config for the hAP AC2:
# dec/27/2022 10:16:33 by RouterOS 7.6
# software id = CZPL-D6U6
# model = RBD52G-5HacD2HnD
# serial number = BEEB0B3D88E9
add admin-mac=C4:AD:34:20:DF:9B auto-mac=no comment=defconf name=bridge
/interface wireless
set [ find default-name=wlan1 ] band=2ghz-b/g/n channel-width=20/40mhz-XX \
    disabled=no distance=indoors frequency=auto installation=indoor mode=\
    ap-bridge ssid=SSID-10 wireless-protocol=802.11
set [ find default-name=wlan2 ] band=5ghz-a/n/ac channel-width=\
    20/40/80mhz-XXXX disabled=no distance=indoors frequency=auto \
    installation=indoor mode=ap-bridge ssid=SSID-10 wireless-protocol=802.11
add comment=defconf name=WAN
add comment=defconf name=LAN
add name=default-dhcp ranges=192.168.88.100-192.168.88.254
add address-pool=default-dhcp interface=bridge name=defconf
add bridge=bridge comment=defconf interface=wlan2
    192.168.88.0
/ip dhcp-client
add address=192.168.88.0/24 comment=defconf dns-server=192.168.88.3 gateway=\
    192.168.88.1
set allow-remote-requests=yes
/ip dns static
    established,related,untracked
    invalid
    in-interface-list=!LAN
    ipsec-policy=in,ipsec
    ipsec-policy=out,ipsec
    connection-state=invalid
add action=dst-nat chain=dstnat comment=HTTPS dst-address=204.168.X.X \
    dst-port=443 protocol=tcp to-addresses=192.168.88.2
add action=dst-nat chain=dstnat comment=SSH dst-address=204.168.X.X \
    dst-port=22 protocol=tcp to-addresses=192.168.88.2 to-ports=22
add action=masquerade chain=srcnat comment=Hairpin dst-address=192.168.88.2 \
    out-interface=bridge protocol=tcp src-address=192.168.88.0/24
add disabled=yes distance=1 dst-address=0.0.0.0/0 gateway=*9 pref-src="" \
    routing-table="VPN Indica" scope=30 suppress-hw-offload=no target-scope=\
    10
/ipv6 firewall address-list
/system clock
set time-zone-name=Europe/Amsterdam
It is pretty default stuff with some port forwarding.
The wAP AC2 is in factory reset state at the moment.
I think I need to create VLAN 10 & 20, make port 5 on hapac and port 1 on wapac a trunk for [10,20], make port 2 on wapac an access port for VLAN 20. Then add a DHCP server and pool on VLAN 20... Please guide me in the right direction! ;-)
Thanks in advance!
anav
Re: Chained VLAN
Tue Dec 27, 2022 8:54 pm
/interface wireless
/interface vlan
add interface=bridge name=VLAN10 vlan-id=10
add interface=bridge name=VLAN20 vlan-id=20
add name=guest-dhcp ranges=192.168.28.100-192.168.28.254
add address-pool=default-dhcp interface=VLAN10 name=home
add address-pool=guest-dhcp interface=VLAN20 name=guest
add bridge=bridge comment=defconf interface=ether2 ingress-filtering=yes frame-types=admit-priority-and-untagged pvid=10
add bridge=bridge comment=defconf interface=ether3 ingress-filtering=yes frame-types=admit-priority-and-untagged pvid=10
add bridge=bridge comment=defconf interface=ether4 ingress-filtering=yes frame-types=admit-priority-and-untagged pvid=10
add bridge=bridge comment=defconf interface=ether5 ingress-filtering=yes frame-types=admit-only-tagged
add bridge=bridge comment=defconf interface=wlan1 ingress-filtering=yes frame-types=admit-priority-and-untagged pvid=10
add bridge=bridge comment=defconf interface=wlan2 ingress-filtering=yes frame-types=admit-priority-and-untagged pvid=10
/interface bridge vlan
add bridge=bridge tagged=bridge,ether5 vlan-ids=20
add bridge=bridge tagged=bridge,ether5 untagged=ether2,ether3,wlan1,wlan2 vlan-ids=10
add interface=VLAN10 list=LAN
add interface=VLAN20 list=LAN
add address=192.168.88.1/24 comment=defconf interface=VLAN10 network=\
192.168.88.0
add address=192.168.28.1/24 comment=defconf interface=VLAN20 network=\
192.168.28.0
/ip dhcp-client
192.168.88.1
add address=192.168.28.0/24 comment=defconf dns-server=192.168.28.1 gateway=\
192.168.28.1
invalid
add action=accept chain=input comment="accept all LAN traffic" in-interface-list=LAN
add action=drop chain=input comment="drop all else"
add action=accept chain=forward in-interface-list=LAN out-interface-list=WAN comment="internet traffic"
add action=accept chain=forward comment="port forwarding" connection-nat-state=dstnat
add action=drop chain=forward comment="drop all else"
WAPAC2
add ingress-filtering=no name=bridge-wap
ether1 name=ether1-Incoming
ether2 name=ether2-Toguest
/interface vlan
add interface=bridge-wap name=HOME vlan-id=10
add name=management
/interface wireless
{ ASSUMING WLAN1 and WLAN2 also using vlan10 }
add bridge=bridge comment=defconf interface=ether1 ingress-filtering=yes frame-types=admit-only-tagged
add bridge=bridge comment=defconf interface=ether2 ingress-filtering=yes frame-types=admit-only-tagged
add bridge=bridge tagged=bridge,ether1,ether2 vlan-ids=20
add bridge=bridge tagged=bridge,ether1 untagged=wlan1,wlan2 vlan-ids=10
set discover-interface-list=management
add interface=HOME list=management
add address=192.168.88XX/24 comment=defconf interface=HOME network=192.168.88.0 { "IP of WAPAC on home subnet }
ip dns
set allow-remote-requests=yes servers=192.168.88.3 comment="dns through trusted subnet gateway"
add disabled=no dst-address=0.0.0.0/0 gateway=192.168.88.1 comment="ensures route avail through trusted subnet gateway"
/tool mac-server
/tool mac-server mac-winbox
set allowed-interface-list=management
After each config is entered go back to bridge entry and set vlan-filtering=yes
sogware
Re: Chained VLAN
Wed Dec 28, 2022 12:29 pm
Thank you so much!
I will try it this evening...
Users browsing this forum: Lupin and 66 guests
