fbalau
Please launch hAP with AX3000 or above
Fri Dec 23, 2022 3:05 am
Currently using hAP ac with 5GHz theoretical max speed of 1300Mbps, I want to upgrade to WIFI 6, but the hAP ax2 specification shows 5GHz theoretical max speed of 1200Mbps, which is lower than the existing hAP ac. So it's hard to convince myself to buy this product.
Thus, please consider to launch hAP ax products with AX3000 or above.
R1CH
Re: Please launch hAP with AX3000 or above
Fri Dec 23, 2022 1:32 pm
hAP AC2/3 is also only a two chain device, so it can't possibly be faster - it maxes out at 866mbps. While I would also like to see more chains, most client devices are only two chain so the benefits in real world scenarios are limited.
normis
Fri Dec 23, 2022 1:34 pm
mkx
Fri Dec 23, 2022 1:40 pm
@OP: if we want to nitpick: hAP ax3 is an ax1800 device. And audience is ac3100 device. But @R1CH is right by saying none of ratings help much in most real-life scenarios where clients can go up to 1200 (theoretically) or around 600Mbps (practically). More chains (e.g. 4 in case of audience's high 5GHz radio) doesn't give throughput boost, it rather helps in sub-ideal conditions (beam forming etc.)
biomesh
Long time Member
Long time Member
Fri Dec 23, 2022 3:10 pm
More chains do help wrt MU-MIMO.
The cpu/ram would also need to be adjusted to handle the extra load.
mkx
Fri Dec 23, 2022 3:25 pm
It sure does (if clients are MU-MIMO capable as well). So does having 3+ radios (like Audience has). But for single client throughput all of that matters very little (none to be exact apart from beam forming which can enhance SINR a bit and thus gives better single-user throughput when that user is in non-ideal radio conditions which already affect throughput).
My impression is that most users asking for ax5000+ performance are not concerned about massive multi-user combined performance, they somehow expect to get to multi-gig single-user performance. Which won't happen.
R1CH
Fri Dec 23, 2022 8:59 pm
Ah yeah, forgot the original was 3 chain, but the CPU is too weak to actually get more throughput than 2 chains.
hecatae
Fri Dec 23, 2022 9:50 pm
I'd pick up the Audience and wait for 6e or 7.
fbalau
Wed Dec 28, 2022 3:07 am
Any roadmap for Wi-Fi 6/6E AX3000 above?
massinia
Sat Dec 23, 2023 5:12 pm
Let's hope 2024 is the year of the Audience ax 🤞🏻
Users browsing this forum: biomesh and 17 guests
