Sertik
team work :parse on special parameters
Fri Dec 23, 2022 9:00 am
Imagine that there is a Microtic Telegram parser capable of performing the functions of a user from a chat. That is, we report something like myFunc par1 par2 ... parN in the chat, the parser transmits this to the Microtic and it executes.
[:parse ":global $funcName; [\$$funcName $parameters]"]
At the same time, I form a string for :parse, in which I pass the name of the executable function to $funcName, and its parameters to $parametrs. Of course, the parameters of the function can be different: positional and named, but only string parameters are incorrectly passed (:type "str")
All this works well for me. But only if the parameters are set in Latin. As soon as I try to pass parameters in the national language (for example in Russian), the construction stops working. I tried to recode the parameters to UTF8, but it doesn't help.
How do I pass parameters in the national language to $parameters ? Or is it impossible ?
I ask Rextended to help me.
rextended
Re: team work :parse on special parameters
Fri Dec 23, 2022 10:17 am
RouterOS accept only 7-bit characters:
Supported first 7-bit ASCII code
NUL@	SOH	STX	ETX	EOT	ENQ	ACK	BEL	BS	HT	LF	VT	FF	CR	SO	SI
DLE	DC1	DC2	DC3	DC4	NAK	SYN	ETB	CAN	EM	SUB	ESC[	FS\	GS]	RS^	US_
SP	!	"	#	$	%	&	'	(	)	*	+	,	-	.	/
0	1	2	3	4	5	6	7	8	9	:	;	<	=	>	?
@	A	B	C	D	E	F	G	H	I	J	K	L	M	N	O
P	Q	R	S	T	U	V	W	X	Y	Z	[	\	]	^	_
`	a	b	c	d	e	f	g	h	i	j	k	l	m	n	o
p	q	r	s	t	u	v	w	x	y	z	{	|	}	~	DEL
Notice:not all control codes from NUL to US do something.
Any other character is unsupported.
Unsupported next 8-bit ASCII CP437 code
Ç	ü	é	â	ä	à	å	ç	ê	ë	è	ï	î	ì	Ä	Å
É	æ	Æ	ô	ö	ò	û	ù	ÿ	Ö	Ü	¢	£	¥	₧	ƒ
á	í	ó	ú	ñ	Ñ	ª	º	¿	⌐	¬	½	¼	¡	«	»
α	ß	Γ	π	Σ	σ	µ	τ	Φ	Θ	Ω	δ	∞	φ	ε	∩
≡	±	≥	≤	⌠	⌡	÷	≈	°	∙	·	√	ⁿ	²	■	NBSP
The unsupported 8-bit characters can be represented as HEX values, from \80 to \FF
Unsupported next 8-bit Latin CP1252 code
€	0x81	‚	ƒ	„	…	†	‡	ˆ	‰	Š	‹	Œ	0x8D	Ž	0x8F
0x90	‘	’	“	”	•	–	—	˜	™	š	›	œ	0x9D	ž	Ÿ
NBSP	¡	¢	£	¤	¥	¦	§	¨	©	ª	«	¬	SHY	®	¯
°	±	²	³	´	µ	¶	·	¸	¹	º	»	¼	½	¾	¿
À	Á	Â	Ã	Ä	Å	Æ	Ç	È	É	Ê	Ë	Ì	Í	Î	Ï
Ð	Ñ	Ò	Ó	Ô	Õ	Ö	×	Ø	Ù	Ú	Û	Ü	Ý	Þ	ß
à	á	â	ã	ä	å	æ	ç	è	é	ê	ë	ì	í	î	ï
ð	ñ	ò	ó	ô	õ	ö	÷	ø	ù	ú	û	ü	ý	þ	ÿ
0x81, 0x8D, 0x8F, 0x90 and 0x9D are unused on CP1252
Unsupported next 8-bit Cyrillic CP1251 code
Ђ 	Ѓ 	‚ 	ѓ 	„ 	… 	† 	‡ 	€ 	‰ 	Љ 	‹ 	Њ 	Ќ 	Ћ 	Џ
ђ 	‘ 	’ 	“ 	” 	• 	– 	— 	0x90 	™ 	љ 	› 	њ 	ќ 	ћ 	џ
NBSP 	Ў 	ў 	Ј 	¤ 	Ґ 	¦ 	§ 	Ё 	© 	Є 	« 	¬ 	SHY 	® 	Ї
° 	± 	І 	і 	ґ 	µ 	¶ 	· 	ё 	№ 	є 	» 	ј 	Ѕ 	ѕ 	ї
А 	Б 	В 	Г 	Д 	Е 	Ж 	З 	И 	Й 	К 	Л 	М 	Н 	О 	П
Р 	С 	Т 	У 	Ф 	Х 	Ц 	Ч 	Ш 	Щ 	Ъ 	Ы 	Ь 	Э 	Ю 	Я
а 	б 	в 	г 	д 	е 	ж 	з 	и 	й 	к 	л 	м 	н 	о 	п
р 	с 	т 	у 	ф 	х 	ц 	ч 	ш 	щ 	ъ 	ы 	ь 	э 	ю 	я
rextended
Fri Dec 23, 2022 10:31 am
UTF-8 is a mix of 8-bit characters for represent all possible languages.
How send 8-bit character to be used with RouterOS?
You must transform the character to HEX equivalent,
for example ±, common on both Latin CP1252 and Cyrillic CP1251 must be converted from UTF-8,
and on UTF-8 that character use two bytes: ± = "\C2\B1"
So, the program that send the string to RouterOS must convert all non-7-bit characters from UTF-8 to escaped HEX sequences.
Fo convert Привіт to one MikroTik usable string:
Example of conversion code
П = \D0\9F
р = \D1\80
и = \D0\B8
в = \D0\B2
і = \D1\96
т = \D1\82
Привіт = "\D0\9F\D1\80\D0\B8\D0\B2\D1\96\D1\82"
But obviously the conversion must happen before the RouterOS is involved on any way.
Or more "simply" (for all languages) use directly only 7-bit characters:
Привіт => Pryvit
The same is for emoticons, at the end are siply characters with specific design.
emoticon example code
"@anav 🍁" = "@anav \F0\9F\8D\81"
Sertik
Fri Dec 23, 2022 11:22 am
Rex, thank you for your detailed answer. I understand everything you wrote.
To convert the parameters to UTF8, I used this function. It does a great job when you need to send CP1251 to Telegram, but it doesn't work when I try to use it for :parse
 Function of converting string CP1251 to UTF8
    # https://forummikrotik.ru/viewtopic.php?p=81457#p81457
:global FuncCP1251toUTF8
:if (!any $FuncCP1251toUTF8) do={:global FuncCP1251toUTF8 do={
        :local cp1251 [:toarray {"\20";"\01";"\02";"\03";"\04";"\05";"\06";"\07";"\08";"\09";"\0A";"\0B";"\0C";"\0D";"\0E";"\0F"; \
                                 "\10";"\11";"\12";"\13";"\14";"\15";"\16";"\17";"\18";"\19";"\1A";"\1B";"\1C";"\1D";"\1E";"\1F"; \
                                 "\21";"\22";"\23";"\24";"\25";"\26";"\27";"\28";"\29";"\2A";"\2B";"\2C";"\2D";"\2E";"\2F";"\3A"; \
                                 "\3B";"\3C";"\3D";"\3E";"\3F";"\40";"\5B";"\5C";"\5D";"\5E";"\5F";"\60";"\7B";"\7C";"\7D";"\7E"; \
                                 "\C0";"\C1";"\C2";"\C3";"\C4";"\C5";"\C6";"\C7";"\C8";"\C9";"\CA";"\CB";"\CC";"\CD";"\CE";"\CF"; \
                                 "\D0";"\D1";"\D2";"\D3";"\D4";"\D5";"\D6";"\D7";"\D8";"\D9";"\DA";"\DB";"\DC";"\DD";"\DE";"\DF"; \
                                 "\E0";"\E1";"\E2";"\E3";"\E4";"\E5";"\E6";"\E7";"\E8";"\E9";"\EA";"\EB";"\EC";"\ED";"\EE";"\EF"; \
                                 "\F0";"\F1";"\F2";"\F3";"\F4";"\F5";"\F6";"\F7";"\F8";"\F9";"\FA";"\FB";"\FC";"\FD";"\FE";"\FF"; \
                                 "\A8";"\B8";"\B9"}];
        :local utf8   [:toarray {"0020";"0020";"0020";"0020";"0020";"0020";"0020";"0020";"0020";"0020";"000A";"0020";"0020";"000D";"0020";"0020"; \
                                 "0020";"0020";"0020";"0020";"0020";"0020";"0020";"0020";"0020";"0020";"0020";"0020";"0020";"0020";"0020";"0020"; \
                                 "0021";"0022";"0023";"0024";"0025";"0026";"0027";"0028";"0029";"002A";"002B";"002C";"002D";"002E";"002F";"003A"; \
                                 "003B";"003C";"003D";"003E";"003F";"0040";"005B";"005C";"005D";"005E";"005F";"0060";"007B";"007C";"007D";"007E"; \
                                 "D090";"D091";"D092";"D093";"D094";"D095";"D096";"D097";"D098";"D099";"D09A";"D09B";"D09C";"D09D";"D09E";"D09F"; \
                                 "D0A0";"D0A1";"D0A2";"D0A3";"D0A4";"D0A5";"D0A6";"D0A7";"D0A8";"D0A9";"D0AA";"D0AB";"D0AC";"D0AD";"D0AE";"D0AF"; \
                                 "D0B0";"D0B1";"D0B2";"D0B3";"D0B4";"D0B5";"D0B6";"D0B7";"D0B8";"D0B9";"D0BA";"D0BB";"D0BC";"D0BD";"D0BE";"D0BF"; \
                                 "D180";"D181";"D182";"D183";"D184";"D185";"D186";"D187";"D188";"D189";"D18A";"D18B";"D18C";"D18D";"D18E";"D18F"; \
                                 "D001";"D191";"2116"}];
        :local convStr "";
        :local code    "";
        :for i from=0 to=([:len $1]-1) do={
            :local symb [:pick $1 $i ($i+1)];
            :local idx  [:find $cp1251 $symb];
            :local key  ($utf8->$idx);
            :if ([:len $key] != 0) do={
                :set $code ("%$[:pick ($key) 0 2]%$[:pick ($key) 2 4]");
                :if ([pick $code 0 3] = "%00") do={:set $code ([:pick $code 3 6])}
            } else={:set code ($symb)};
            :set $convStr ($convStr.$code);
        :return ($convStr);
First, let's say I recode a string with parameters, passing it through the function FUNCTIONP1251TOUTF8,
:local $parameters [$FuncCP1251toUTF8 $parameters]
and then I give it to :parse. Isn 't that right ?
But, parameters containing Russian text are not transmitted.
rextended
Fri Dec 23, 2022 11:47 am
Again?
You seem more focused on refuting (or describing what you done or not) than understanding.
Sertik
Fri Dec 23, 2022 11:57 am
That is , in fact , it cannot be done since Telegram cannot do this ? So this is a limitation of Telegram, not RouterOS?
rextended
Fri Dec 23, 2022 12:05 pm
Telegram use natively UTF-8 and you need a UTF-8 to ASCII to RouterOS converter.
The function FuncCP1251toUTF8 (really made with feet) and also my version for CP1252 (not the best, but more clear)
viewtopic.php?f=9&t=177551#p967513
Is clearly called to_UTF8 because convert RouterOS ASCII characters received to CP125x and to UTF-8 for use it on Telegram & Co.
Instead from Telegram if non-7-bit ascii text (Cyrillic, emoticon & Co.) is used, you receive UTF-8 and RouterOS is unable to directly understand.
Sertik
Fri Dec 23, 2022 12:17 pm
Instead from Telegram if non-7-bit ascii text (Cyrillic, emoticon & Co.) is ued, you receive UTF-8 and RouterOS is unable to directly understand.
is it still possible to somehow solve this problem on RouterOS or is it no longer possible?
rextended
Fri Dec 23, 2022 12:33 pm
Telegram send: "Привіт @Sertik, Привіт @anav 🍁" on UTF-8"
RouterOS receive, if nothing between convert the string:
string code
RouterOS stop parsing at "Ð" because do not understand.
Like you use a function to convert RouterOS to Telegram language, inside RouterOS
you must write a function to convert Telegram to RouterOS language inside Telegram.
Sertik
Fri Dec 23, 2022 12:36 pm
Got it, thanks. The verdict is - impossible. You can close the topic. REX, don't be offended by the incomprehensible and thank you very much!
Users browsing this forum: pyfgcrl and 29 guests
