mfrabbibd
NetMetal ac2 Default Wireless Band?
Sun Dec 25, 2022 5:51 am
Hi all, I've a p2p link with Netmetal ac2 bridge mood. It always connect 2.4ghz first and data always pass through 2.4ghz, if I disable 2.4ghz then 5ghz passes the data. How can I use 5ghz first? I mean if 5ghz failed to connect then 2.4 GHz will activate. I need 5ghz as a default wireless band and 2.4ghz as backup... anyone help? Normis, would you please give me any solution?
Regards.
Ca6ko
Long time Member
Long time Member
Re: NetMetal ac2 Default Wireless Band?
Sun Dec 25, 2022 8:40 pm
Create Connect List and determine the order in which they are connected
Users browsing this forum: Amazon [Bot] and 53 guests
