smotrov
Strange row in interface list
Mon Dec 26, 2022 8:59 pm
I have a strange row in interface list in WebFig -> Interfaces.
It shows
;;; defconf
See attached screenshot.
Would appreciate it if someone explain what could it mean.
RouterOS v7.7rc3
BartoszP
Re: Strange row in interface list
Mon Dec 26, 2022 11:27 pm
Set "inline comments" to "on"
holvoetn
Tue Dec 27, 2022 5:58 am
It's the default config (=defconf) for the line which follows.
And as mentioned by BartoszP, clearly visible when you set comments to inline.
You can also see it when you select bridge and go to the comment section.
Amm0
Tue Dec 27, 2022 6:09 am
It's left over from default config. Unless you're using Quickset to change things in future, you can delete/remove the comment too.
Users browsing this forum: rolfschneider, tolgalen and 43 guests
