MicroMikrotik
Support RFC3021 /31 Point to Point on any ROS version ?
Tue Dec 27, 2022 8:45 am
I would like to know if there is a version of ROS that supports RFC 3021 which allows the use of /31 in point to point.
I have a rather particular setup which consists in announcing a /31 in eBGP and to configure the /31 on the port 3 of one of my routers in order to connect a firewall.
I used the method of putting the IP in /32 and put that of the firewall in address of the network I manage to ping between my two equipment but I do not manage to leave on Internet the Mikrotik does not let pass the traffic.
I did my test on the last version in 6 (6.49.7)
Thank you
kevinds
Long time Member
Long time Member
Re: Support RFC3021 /31 Point to Point on any ROS version ?
Fri Dec 30, 2022 2:32 am
No. Need to use /30's
mrz
Fri Dec 30, 2022 11:37 am
You do not need /30
/32 works with /31 on the remote side.
It may not work if your mentioned firewall is not set up properly and blocks the traffic or incorrectly set up a routing table that does not allow route traffic through the router.
DarkNate
Fri Dec 30, 2022 6:50 pm
Using /31 directly on RouterOS v7.6 works fine for BGP over here.
kevinds
Long time Member
Long time Member
Wed Jan 04, 2023 9:35 am
You do not need /30
Huh? Why would you use different masks?
pcexpert
Sun Feb 05, 2023 4:59 pm
Hi, can you confirm that /31 is working stable with BGP on rosV7.6 / 7.7?
I want to use it for public ip redistribution via iBGP to end clients in VRFs.
waldiwk
Wed Oct 11, 2023 1:44 pm
In /routing/bgp/connection remote.address of the form x.x.x.x without a mask will not work.
If you enter the remote address in the format x.x.x.x/31, it will be ok.
thesysadmin
Mon Jan 08, 2024 7:30 am
Why on Earth, would you need to use /32 on local and /31 on remote? This is a very poor implementation of RFC3021, if you could even call it an attempt.
DarkNate
Mon Jan 08, 2024 7:38 am
RFC3021 is simply not supported on MikroTik platform, I can't imagine what's taking them so long to support this.
kevinds
Long time Member
Long time Member
Tue Jan 16, 2024 1:25 pm
It isn't an attempt, there is no attempt, RFC3021 doesn't work on RouterOS.. That is another user telling you what will work, if you can't use a /30 for some reason.
SomeGuyNamedTate
Fri Feb 02, 2024 6:42 pm
I thought so too but it seems MikroTik has apparently added RFC3021 support at some point (though I can't find anything in any of the changelogs referencing "3021" or "/31"). I just joined the forum so hopefully the screenshot I'm attaching of a box running 7.13.3 successfully using a /31 will be allowed. This particular test was on a pair of CHRs but I also tested using a spare RB5009 running 7.13.3 and no problems there either.
Users browsing this forum: Bing [Bot] and 75 guests
