lazarmihail
CRS328-24P-4S to Cisco 3504 WLC
Tue Dec 27, 2022 4:43 pm
Hi everyone,
I have a question for those that have tried to connect a Cisco wireless lan controller to a Mikrotik switch
In the Cisco world a wireless lan controller would connect to a distribution cisco switch in this way:
Int Gi0/1
switchport
channel-group 1 mode on
no shut
Int Gi0/2
switchport
no shut
interface port-channel 1
switchport
switchport trunk encap dot1q
switchport trunk native vlan 301
switchport trunk allowed vlan all
switchport mode trunk
no shutdown
Now the question is how I can achieve the same setup but with a Mikrotik switch since I have the wireless lan controller connected, I have tried to create bonding, trunk ports, etc but none of them have been a success so far :(
The topology I have is the one attached to this message, let me know please if you had the same issues and how did you solve to connect a Cisco wireless lan controller to a RouterOS switch like CRS328, the one I have.
lazarmihail
Re: CRS328-24P-4S to Cisco 3504 WLC
Tue Dec 27, 2022 8:40 pm
Thank you for the link https://www.firewall.cx/cisco-technical ... tches.html, but as you have seen the port-channel must be ON on the Mikrotik side and I don't think that Mikrotik supports that since I haven't been able to find any documentation about it.
I will try tomorrow to disable LAG and have the WLC connected over a simple trunk port. I don't see any other solution, but it would be a pitty to have 4 links that can be aggregated but unusable because Mikrotik doesn't support port-channel mode ON.
AKAGHT
Tue Dec 27, 2022 8:53 pm
port-channel mode is CISCO only Protocol, is like saying it is pity that I cannot use a catalyst 7500 chase, full of Cisco hardware because it does not know EOIP.
lazarmihail
Tue Dec 27, 2022 9:37 pm
Nope, but I was under the impression that LACP mode ON is under the open source protocol 802.3ad but it seems like is not. Therefore, I'll give it a try with the WLC being configured without LAG and the SW with a trunk port and see if it works.
Users browsing this forum: Amazon [Bot], kevinlukas and 78 guests
