jaxbluesbass
Json on PostMan
Tue Dec 27, 2022 6:52 pm
Hi all sorry on Postman i try tu run script in JSON but doesn't work
some one can help me?
jaxbluesbass
Re: Json on PostMan
Wed Dec 28, 2022 4:17 pm
Solved alone thanks for all as usal
normis
Re: Json on PostMan
Wed Dec 28, 2022 4:19 pm
Can you share the solution? Maybe there were no answers, as nobody knew how to do it right, and this topic can help somebody else
Amm0
Re: Json on PostMan
Wed Dec 28, 2022 8:09 pm
Why someone come back to post unhelpful info, dunno.
It's the holidays, and I use postman, and like guessing games. Bet's it's the "Authorization" wasn't set in the tab. Postman generally shows a "green dot" if stuff is set. Maybe not, but the "Authorization" tab needs to be set to "Basic Auth" and your username/password* – no "green dot" in the original for REST to work on the postman side.
*Postman does scheme to mange passwords/variables, RTFM
Users browsing this forum: No registered users and 55 guests
