smotrov
Playstation & Youtube errors
Wed Dec 28, 2022 5:03 pm
Replaced my AirPort Extreme with brand new hAp AX2.
Now I'm having certain issues with Playstation 4 and Youtube app on both Android and Apple TV.
When PS4 wakes up after sleep mode it has internet connection but can not enter PlayStation Network. PS4 shows (NW-31254-5) DNS error.
Same time Youtube app keep saying that there is no internet connection, despite the fact that Speedtest on the same devices shows that internet is available there.
Both issues are disappearing if I'll reboot client devices. Then the issue comes back when they wake up from sleep mode. Reboot of client devices is temporarily fixing the problem, until next sale.
I presume, that there is something wrong with NAT / Port Forwarding.
A have almost factory setup on my hAp AX2. I also have static IP from my ISP.
Any advices would be highly appreciated.
rextended
Re: Playstation & Youtube errors
Wed Dec 28, 2022 5:09 pm
probably instead of configure ax2 only as plain switch+ap, you set it as router and the multiple NAT and DNS cache cause issues...
smotrov
Wed Dec 28, 2022 5:11 pm
here is my setup
# dec/28/2022 17:09:37 by RouterOS 7.7rc3
# software id = AHJZ-PQ1I
# model = C52iG-5HaxD2HaxD
add admin-mac=18:FD:74:BB:CB:C9 auto-mac=no comment=defconf name=bridge
/interface wifiwave2
set [ find default-name=wifi2 ] channel.skip-dfs-channels=10min-cac configuration.country=Ukraine .mode=ap .ssid="AirPort Extreme Slow" disabled=no mtu=1500 name=Private2GHz \
    security.authentication-types=wpa2-psk,wpa3-psk
set [ find default-name=wifi1 ] channel.skip-dfs-channels=all configuration.country=Ukraine .mode=ap .ssid="AirPort Extreme" disabled=no mtu=1500 name=Private5GHz \
add configuration.country=Ukraine .mode=ap .ssid="Glory to Ukraine app.191" disabled=no mac-address=1A:FD:74:BB:CB:CE master-interface=Private2GHz name=Guest2GHz
add configuration.country=Ukraine .mode=ap .ssid="Glory to Ukraine app.191" disabled=no mac-address=1A:FD:74:BB:CB:CD master-interface=Private5GHz name=Guest5GHz
add comment=defconf name=WAN
add comment=defconf name=LAN
add name=dhcp ranges=192.168.88.10-192.168.88.254
add address-pool=dhcp interface=bridge lease-time=1w name=defconf
/port
set 0 name=serial0
/interface bridge filter
add action=drop chain=forward in-interface=Guest5GHz
add action=drop chain=forward out-interface=Guest5GHz
add action=drop chain=forward in-interface=Guest2GHz
add action=drop chain=forward out-interface=Guest2GHz
add bridge=bridge comment=defconf interface=Private5GHz
add bridge=bridge comment=defconf interface=Private2GHz
add bridge=bridge interface=Guest5GHz
add bridge=bridge interface=Guest2GHz
/interface detect-internet
set detect-interface-list=all internet-interface-list=all lan-interface-list=all wan-interface-list=all
add address=192.168.88.1/24 comment=defconf interface=bridge network=192.168.88.0
/ip dhcp-client
add address=192.168.88.0/24 comment=defconf dns-server=192.168.88.1 gateway=192.168.88.1
set allow-remote-requests=yes
/ip dns static
add action=accept chain=input comment="defconf: accept to local loopback (for CAPsMAN)" dst-address=127.0.0.1
add action=fasttrack-connection chain=forward comment="defconf: fasttrack" connection-state=established,related hw-offload=yes
add action=drop chain=forward comment="defconf: drop all from WAN not DSTNATed" connection-nat-state=!dstnat connection-state=new in-interface-list=WAN
/ip service
set www-ssl certificate=Webfig disabled=no
/ip upnp
set enabled=yes
/ip upnp interfaces
add interface=bridge type=internal
add interface=ether1 type=external
/ipv6 firewall address-list
/ipv6 firewall filter
add action=accept chain=input comment="defconf: accept ICMPv6" protocol=icmpv6
add action=accept chain=input comment="defconf: accept UDP traceroute" port=33434-33534 protocol=udp
add action=accept chain=input comment="defconf: accept DHCPv6-Client prefix delegation." dst-port=546 protocol=udp src-address=fe80::/10
add action=accept chain=input comment="defconf: accept IKE" dst-port=500,4500 protocol=udp
add action=accept chain=input comment="defconf: accept ipsec AH" protocol=ipsec-ah
add action=accept chain=input comment="defconf: accept ipsec ESP" protocol=ipsec-esp
add action=accept chain=input comment="defconf: accept all that matches ipsec policy" ipsec-policy=in,ipsec
add action=drop chain=input comment="defconf: drop everything else not coming from LAN" in-interface-list=!LAN
add action=accept chain=forward comment="defconf: accept established,related,untracked" connection-state=established,related,untracked
add action=drop chain=forward comment="defconf: drop packets with bad src ipv6" src-address-list=bad_ipv6
add action=drop chain=forward comment="defconf: drop packets with bad dst ipv6" dst-address-list=bad_ipv6
add action=drop chain=forward comment="defconf: rfc4890 drop hop-limit=1" hop-limit=equal:1 protocol=icmpv6
add action=accept chain=forward comment="defconf: accept ICMPv6" protocol=icmpv6
add action=accept chain=forward comment="defconf: accept IKE" dst-port=500,4500 protocol=udp
add action=accept chain=forward comment="defconf: accept ipsec AH" protocol=ipsec-ah
add action=accept chain=forward comment="defconf: accept ipsec ESP" protocol=ipsec-esp
add action=accept chain=forward comment="defconf: accept all that matches ipsec policy" ipsec-policy=in,ipsec
add action=drop chain=forward comment="defconf: drop everything else not coming from LAN" in-interface-list=!LAN
/system clock
set time-zone-name=Europe/Kiev
/system logging
add action=disk topics=critical
add action=disk topics=error
add action=disk topics=warning
/system package update
set channel=testing
/system watchdog
set automatic-supout=no watchdog-timer=no
/tool graphing interface
add
/tool graphing queue
add
/tool graphing resource
add
/tool mac-server
/tool mac-server mac-winbox
anav
Wed Dec 28, 2022 5:16 pm
Serial number should be removed from the previous post.
Also as per rextendeds query, does the ax3 get a public IP or is it attached to an ISP router??
Who advised you to use bridge filters, vice the standard firewall filters,,,,,use of them is an advanced user type of knowledge!
I also dont understand why you dont at least use two different vlans, one for home use and one for guest use ???
(or more clearly two different subnets).
smotrov
Wed Dec 28, 2022 5:24 pm
Thank you Anav, for your reply.
I removed my serial from the previous post.
Regarding firewall filters. This setup is just from default automated setup from MikroTik app. So strictly speaking it was MikroTik advice :-)
Do you think this setup is not correct and should be changed completely?
anav
Wed Dec 28, 2022 5:42 pm
SHOWING MAJOR CHANGES
add admin-mac=18:FD:74:BB:CB:C9 auto-mac=no comment=defconf name=bridge vlan-filtering=yes { done after config is completed last step }
/interface vlan
add interface=bridge name=VLANH-10 vlan-ids=10
add interface=bridge name=VLANG-20 vlan-ids=20
add name=dhcp-guest ranges=192.168.28.10-192.168.28.254
add address-pool=dhcp interface=VLANH-10 lease-time=1w name=defconf
add address-pool=dhcp-guest interface=VLANG-20 lease-time=1w name=defconf
add bridge=bridge comment=defconf interface=ether2 ingress-filtering=yes frame-types=admit-priority-and-untagged pvid=10
add bridge=bridge comment=defconf interface=ether3 ingress-filtering=yes frame-types=admit-priority-and-untagged pvid=10
add bridge=bridge comment=defconf interface=ether4 ingress-filtering=yes frame-types=admit-priority-and-untagged pvid=10
add bridge=bridge comment=defconf interface=ether5 ingress-filtering=yes frame-types=admit-priority-and-untagged pvid=10
add bridge=bridge comment=defconf interface=Private5GHz ingress-filtering=yes frame-types=admit-priority-and-untagged pvid=10
add bridge=bridge comment=defconf interface=Private2GHz ingress-filtering=yes frame-types=admit-priority-and-untagged pvid=10
add bridge=bridge interface=Guest5GHz ingress-filtering=yes frame-types=admit-priority-and-untagged pvid=20
add bridge=bridge interface=Guest2GHz ingress-filtering=yes frame-types=admit-priority-and-untagged pvid=20
/interface bridge vlan
add bridge=bridge tagged=bridge untagged=ether2,ether3,ether4,ether5,Private5GHz,Private2GHz vlan-ids=10
add bridge=bridge tagged=bridge untagged=Guest5GHz,Guest2GHz vlan-ids=20
set discover-interface-list=MANAGE
set detect-interface-list=NONE
add comment=defconf interface=VLANH-10 list=LAN
add comment=interface=VLANG-20 list=LAN
add interface=VLANH-10 list=MANAGE { the guest network should not be part of certain list items }
add address=192.168.88.1/24 comment=defconf interface=VLANH-10 network=192.168.88.0
add address=192.168.28.1/24 comment=defconf interface=VLANG-20 network=192.168.28.0
/ip dhcp-client
add address=192.168.28.0/24 comment=defconf dns-server=192.168.28.1 gateway=192.168.28.1
add action=accept chain=input comment="allow home subnet" in-interface-list=MANAGE
add action=accept chain=input in-interface=VLANG-20 dst-port=53 protocol=tcp comment="allow dns services"
add action=accept chain=input in-interface=VLANG-20 dst-port=53 protocol=udp
add action=drop chain=input comment="drop all else"
{ put this in rule only after the three above }
add action=accept chain=forward in-interface-list=LAN out-interface-list=WAN {allows internet traffic}
add action=accept chain=forward comment="allow port forwarding" connection-nat-state=dstnat
add action=drop chain=forward comment="drop all else"
/ip upnp
set enabled=yes ???????? WHy do you need UPNP, normally not required!!
/tool mac-server
set allowed-interface-list=NONE { not a secure method of connection no not used }
set allowed-interface-list=MANAGE
anav
Wed Dec 28, 2022 5:46 pm
If the MT router is not getting a public IP, then perhaps you are looking at more a switch/AP setup?
If so, how much access to the ISP router do you have ( can forward ports at least ?? )
smotrov
Wed Dec 28, 2022 7:45 pm
Dear anav, thank you for such a comprehensive reply!
Have few issues.
Can't add records to DHCP server. Should I delete existing one first?
[admin@MikroTik] /ip/dhcp-server> print
Columns: NAME, INTERFACE, ADDRESS-POOL, LEASE-TIME
# NAME     INTERFACE  ADDRESS-POOL  LEASE-TIME
0 defconf  bridge     dhcp          1w
[admin@MikroTik] /ip/dhcp-server> add address-pool=dhcp interface=VLANH-10 lease-time=1w name=defconf
failure: server with such name already exists
[admin@MikroTik] /ip/dhcp-server> add address-pool=dhcp-guest interface=VLANG-20 lease-time=1w name=defconf
/interface/bridge/port does not allowing frame-types=admit-priority-and-untagged
 /interface/bridge/port> add bridge=bridge comment=defconf interface=ether2 ingress-filtering=yes frame-types=admit-priority-and-untagged pvid=10
syntax error (line 1 column 86)
If hitting TAB in the terminal it suggests following option
admit-all admit-only-untagged-and-priority-tagged admit-only-vlan-tagged
So I presume I should put something instead of MANAGE everywhere?
Thank you.
smotrov
Wed Dec 28, 2022 9:59 pm
Previous router (Apple AirPort Extreme) was saying that I have double NAT.
anav
Wed Dec 28, 2022 11:31 pm
Regardless of the apple, what is in between the MT router and the internet???
Yes my syntax is probably not correct, its close enough for you to make the right selections. :-)
No I meant MANAGE,
note that first you have to add the list MANAGE,
then the VLAN subnet to the list as a member, and then we use the list MANAGE in various spots
The only way to get those issues is if you have duplicates......... modify the first one and then add the second one, should have worked fine.
smotrov
Wed Dec 28, 2022 11:59 pm
I have twisted pair cable from my provider right into my apartment. I suppose there is ISP's router somewhere in the building which connected via optic fiber to their base. I'm a software developer and have pretty limited knowledge in networking. Only basic staff. Can I ask you to give me a hint how can I found what is in between MT and internet?
Based on your suggestions did following configuration. I believe I did something wrong. Because there is no internet after it was applied. Restored from backup.
[admin@MikroTik] > export hide-sensitive
# dec/28/2022 23:48:07 by RouterOS 7.7rc3
set [ find default-name=wifi2 ] channel.skip-dfs-channels=10min-cac configuration.country=Ukraine .mode=ap .ssid="AirPort Extreme Slow" disabled=no mtu=1500 name=Private2GHz security.authentication-types=wpa2-psk,wpa3-psk
set [ find default-name=wifi1 ] channel.skip-dfs-channels=all configuration.country=Ukraine .mode=ap .ssid="AirPort Extreme" disabled=no mtu=1500 name=Private5GHz security.authentication-types=wpa2-psk,wpa3-psk
/interface vlan
add interface=bridge name=VLANG-20 vlan-id=20
add interface=bridge name=VLANH-10 vlan-id=10
add address-pool=dhcp interface=VLANH-10 lease-time=1w name=privat
add address-pool=dhcp-guest interface=VLANG-20 lease-time=1w name=guest
/port
set 0 name=serial0
add comment=defconf interface=VLANG-20 list=LAN
/ip dhcp-client
/ip dns static
add action=accept chain=input comment="allow home subnet" in-interface-list=LAN
add action=accept chain=input comment="allow dns services" dst-port=53 in-interface=VLANG-20 protocol=tcp
add action=accept chain=input dst-port=53 in-interface=VLANG-20 protocol=udp
/ip service
/ip upnp interfaces
/system clock
/system logging
set channel=testing
/system watchdog
add
add
add
/tool mac-server
smotrov
Re: Playstation & Youtube errors  [SOLVED]
Thu Dec 29, 2022 1:46 am
It looks like I did fixed the issue.
[admin@MikroTik] > /ip/dhcp-server/network/print
Columns: ADDRESS, GATEWAY, DNS-SERVER
# ADDRESS          GATEWAY       DNS-SERVER
;;; defconf
0 192.168.88.0/24  192.168.88.1  8.8.8.8
                                 8.8.4.4
                                 9.9.9.9
I've just switched dns server from MT (192.168.88.1) to public ones and all clients (Apple TV, PlayStation 4, Mi TV Stick) now working flawlessly.
Do not really understand why they didn't not liked own MT DNS...
accarda
Fri Dec 30, 2022 11:37 am
Because in your setup you had MT to be your DNS, but you forgot to add DNS servers where your MT should have made query to.
So your clients pointed to a resolver which didn't have upstream DNS to query.
set allow-remote-requests=yes servers=8.8.8.8,8.8.4.4,9.9.9.9
rextended
Fri Dec 30, 2022 11:55 am
@accarda
Do not forgot any on that RouterBOARD if the DHCP Server on previous router give correct DNSs:
/ip dhcp-client
add
accarda
Fri Dec 30, 2022 1:55 pm
In that case he would need to check what the other router was passing as DNS servers through DHCP server… may be it was passing router’s IP itself, but we can only guess at this point.
Users browsing this forum: JDF and 98 guests
