MarkReyan
Send message from Mikrotik to the telegram group
Wed Dec 28, 2022 10:14 pm
Hello
I'm trying to send a message from Mikrotik to my telegram group using bot
[ I already added a new Traffic Monitor] my OS version is: 6.47.10
and this is the script:
/tool fetch
url="https://api.telegram.org/bot<TOKEN>/sen ... xt=Message"
already ,I have been set the <TOKEN> AND <CHAT_ID>
I'm wondering if there is need to upgrade the OS.
I tried to execute the script in the terminal I got this error
failure: invalid URL protocol
can you help me please
rextended
Re: Send message from Mikrotik to the telegram group
Thu Dec 29, 2022 6:14 pm
correct syntax is
/tool fetch url="https://api.telegram.org/bot<TOKEN>/sendMessage\3Fchat_id=<CHAT ID or @channelusername>&text=<MESSAGE (max 4096 chrs)>"
But you can use only space, numbers and upper and lowercase latin letters, no special chars or signs.
supported characters code
<SPACE>	!	"	 	$	 	 	'	(	)	*	 	,	-	.
0	1	2	3	4	5	6	7	8	9	 	;	<	=	>
 	A	B	C	D	E	F	G	H	I	J	K	L	M	N	O
P	Q	R	S	T	U	V	W	X	Y	Z	[	\	]	^	_
`	a	b	c	d	e	f	g	h	i	j	k	l	m	n	o
p	q	r	s	t	u	v	w	x	y	z	{	|	}	~
The list can have errors.
You must urlencode first the text if is not standard or you must use reserved chrs like &, #, etc.
For example if the message must be Привіт <MESSAGE> must be equal to %D0%9F%D1%80%D0%B8%D0%B2%D1%96%D1%82
MarkReyan
Fri Dec 30, 2022 10:35 am
I tried that doesn't work
and I can't see any thing in the log that means the script isn't working
rextended
Fri Dec 30, 2022 11:21 am
Post full script
MarkReyan
Fri Dec 30, 2022 12:57 pm
I tried All of them
/tool fetch url="https://api.telegram.org/bot5801257/sendMessage?
chat_id=10559&text=%20%22Donload%20is%20more%20than%202M" keep-result=no;
chat_id=1055&text=%20%22Donload%20is%20more%20than%202M"
chat_id=1055&text=Download speed is more than 25MB"
/tool fetch url="https://api.telegram.org/bot5801257/sendMessage\
chat_id=-1055&text=Download speed is more than 25MB"
rextended
Fri Dec 30, 2022 1:00 pm
I hope you post false bot and chatid...
What error you give?
For me, with your URL is:
error code
failure: closing connection: <401 Unauthorized> 149.154.167.220:443 (4)
MarkReyan
Fri Dec 30, 2022 1:13 pm
sure, I posted false bot and chatID.
actually seems not working I can't see any thing in the log
after I pasted the script in the terminal I got this line below:
expected end of command (line 1 column 105)
rextended
Re: Send message from Mikrotik to the telegram group  [SOLVED]
Fri Dec 30, 2022 1:30 pm
Regardless if work or not,
you have read my previous post???
Try this, without touch anything except set correct token and chat id:
/tool fetch url="https://api.telegram.org/bot<TOKEN>/sendMessage\3Fchat_id=<CHAT-ID>&text=test+message"
Users browsing this forum: No registered users and 41 guests
