Broesel
Router OS 7 broke Mesh
Thu Dec 29, 2022 6:13 pm
had a Network running WDS Mesh fine with ROS 6, now updated to 7.7rc3 and Mesh broke down.
Connects, and keeps disconnecting after 1 Minute:
wlan1: failed to set bridge port for wlan1, reason: std failure: timeout (13)
64:D1:54:B2:19:5E@wlan1: disconnected, no beacons received, signal strength -53
As soon as i use a "normal" bridge, and just use "dynamic" instead of "dynamic mesh" for WDS the connection is fine.
Any ideas whats wrong here?
Best reagrds,
Broesel
piotr0777
Re: Router OS 7 broke Mesh
Sun Jan 22, 2023 4:40 am
I seem to have the same issue. Any luck solving it?
MasterCATZ
Sat Sep 02, 2023 7:39 am
anyone else gotten working ?
mine used to work a treat with the 1x unit with Wired Connection PTP Bridge CPE and all the others PTP Bridge AP ,
but then they changed the "Quick Set" to only do 5ghz band , and that rendered all the IOT devices unable to have a wifi connection
only other option was "Home AP Dual" , but that did not help me
and "Home Mesh" completely broke everything
the config will not save unless you manually set Local network an IP Adress rendering the Internet Automatic from a DHCP useless
and it creates using CAPsMAN instead of using MESH ? and CAPsMAN requires every device to be wired ?
and the wireless interfaces have no supported channels set ?
Users browsing this forum: hazem and 98 guests
