telecomnetwork2022
ISP
Sat Dec 31, 2022 12:35 pm
i have
Last edited by telecomnetwork2022 on Fri Jan 06, 2023 10:22 am, edited 3 times in total.
mkx
Re: ISP & SPEEDTEST
Sat Dec 31, 2022 12:46 pm
You most probably can't do it. Provider is determined by speedtest server and passed to browser/app via encrypted (https) communication connection which you can not change.
erlinden
Re: ISP & SPEEDTEST
Sat Dec 31, 2022 12:47 pm
What problem does it solve? By the public IP address you are always able to determine the ISP.
telecomnetwork2022
Re: ISP & SPEEDTEST
Sat Dec 31, 2022 1:09 pm
i found this buts i think too old its not working for me
https://jarkom.net/mengubah-ip-publik-d ... unakan-vpn
pe1chl
Re: ISP & SPEEDTEST
Sat Dec 31, 2022 2:21 pm
Likely you can only achieve what you want by getting one of the commercial VPN services (that is compatible with RouterOS) and route ALL your traffic via that VPN.
(which requires that your router has hardware acceleration for the chosen VPN, or else it will be quite slow)
All those methods that try to identify the traffic are going to fail, either now or in the future.
telecomnetwork2022
Re: ISP & SPEEDTEST
Sat Dec 31, 2022 2:25 pm
so i have 2 wan with load balance
when make speedtest show me WAN1 ISP Providor Name sometimes show me WAN2 ISP Providor Name
Can i set any speedtest connection to WAN1 ?
pe1chl
Re: ISP & SPEEDTEST
Sat Dec 31, 2022 2:34 pm
No.
ingdaka
Trainer
Trainer
Re: ISP & SPEEDTEST
Sat Dec 31, 2022 3:41 pm
You can set DST port 8080 but this will work only with speedtest.net, all servers or OOKLA use port 8080.
pe1chl
Re: ISP & SPEEDTEST
Sat Dec 31, 2022 4:00 pm
LibreSpeed uses the normal http/https ports, nothing makes it different from a normal website. And it shows the ISP info as well.
telecomnetwork2022
Re: ISP & SPEEDTEST
Sun Jan 01, 2023 11:04 am
I Have Adress List contain a website and his IP can you help me to make rule send any connection for this site from client to wan2 not wan 1
pe1chl
Re: ISP & SPEEDTEST
Sun Jan 01, 2023 12:28 pm
It is not possible to make rules for someone else's router when they have not posted an export of their current configuration.
telecomnetwork2022
Re: ISP & SPEEDTEST
Sun Jan 01, 2023 1:55 pm
nothing possible in mikrotik
Amm0
Re: ISP & SPEEDTEST
Sun Jan 01, 2023 2:07 pm
Too much is possible is the problem, why a sanitized posting of the config helps.
See viewtopic.php?t=182601
telecomnetwork2022
Re: ISP & SPEEDTEST
Mon Jan 02, 2023 10:43 am
Nothing impossible in mikrotik the problem sloved
solution :
replace youtube for any website or ip want
thanks for ibrahim almasry egypetion
pe1chl
Re: ISP & SPEEDTEST
Mon Jan 02, 2023 11:24 am
solution :
Yes, THAT is not a problem. The problem is to make this work "for any speedtest" as you originally asked!
You cannot know the IP and not even the DNS name of every speedtest in advance. That is where it fails.
telecomnetwork2022
Re: ISP & SPEEDTEST
Mon Jan 02, 2023 11:58 am
solution :
no thats wrong you can make it easy throw this following code
ADD Role in Managle = Prerouting / TPC IP 6 protocol / in TSL HOST write *speedtest* and in action make add to address list
the rule will monitor any connection from speedtest website and APP and add all ip in address list (tested 100%)
just you can change aby website want in TSL HOST write *speedtest*
but you cant add all speedtest website in world this is possible so i was needed website one as i mentioned in top post
pe1chl
Re: ISP & SPEEDTEST
Mon Jan 02, 2023 12:40 pm
How does your solution work when you go to http://44.137.42.33/ ??
Or even when you go to http://speedtest.pi9noz.ampr.org/ which is the DNS name of that address?
telecomnetwork2022
Re: ISP & SPEEDTEST
Mon Jan 02, 2023 1:08 pm
Just Write *ampr* in TSL host and the rule will automaticly add all ips and domain to the new list
rextended
Re: ISP & SPEEDTEST
Mon Jan 02, 2023 1:24 pm
@telecomnetwork2022:
@pe1chl is absolutely right, and it is perfectly useless to contradict him,
it is impossible to know in advance all the names and all the IPs of the dozens of thousands of speedtests that exist.
Just for example, not all speedtest have speed and test on name:
speedsmart . net
fast . com
meter . net
etc.
And tag "speed" you can broken connection, for example for "speed pay", "fast pay", etc.
(and with TLS 1.3 any "TLS" rule is absolutely useless)
rextended
Re: ISP & SPEEDTEST
Mon Jan 02, 2023 1:29 pm
@pe1chl
telecomnetwork2022
Re: ISP & SPEEDTEST
Mon Jan 02, 2023 1:33 pm
speedsmart . net
fast . com
meter . net
etc.
no connection will not broken just he go to another isp in mikrotik are thats right
rextended
Re: ISP & SPEEDTEST
Mon Jan 02, 2023 2:06 pm
I do not want go on details, but, for example, simply the payment platform want the same IP,
if one of called subdomains or domain with other names is reached with the other IP,
for security reason can not be completed the payment.
telecomnetwork2022
Re: ISP & SPEEDTEST
Mon Jan 02, 2023 2:27 pm
in this case you can remove TSL host domain and fill address list manual with IP website you want thank
rextended
Re: ISP & SPEEDTEST
Mon Jan 02, 2023 2:42 pm
...and the lists are constantly changing, the same site can very well have different IPs for each test done.
Ok, you don't like to get the point, I don't like to answer this again.
telecomnetwork2022
Re: ISP & SPEEDTEST
Mon Jan 02, 2023 2:58 pm
any way . Thank you for your join my post
pe1chl
Re: ISP & SPEEDTEST
Mon Jan 02, 2023 3:13 pm
That will not work because this server does not use TLS. Furthermore, it would be unwarranted because the ampr.org domain contains many services and only a few speedtest servers.
It also is not clear why you want all this at all. It seems like you are bothered by the fact that the users reveal that your traffic is sometimes routed via ISP #2, that must be hidden from them.
However, what if they instead of a speedtest visit a "what is my IP" site? E.g. whatismyip.com. That will display the same (or even more) information.
Are you going to redirect those to ISP #1 as well? Where does it end?
That is not really true, the first connection to any site that matches your criteria is likely to be broken. You cannot route a TCP connection that is already established halfway through.
telecomnetwork2022
Re: ISP & SPEEDTEST
Mon Jan 02, 2023 4:23 pm
oH ? Are you mean the server can route just one connection in same time ?
pe1chl
Re: ISP & SPEEDTEST
Mon Jan 02, 2023 4:52 pm
No, what I mean is: when loadbalancing has initiated a connection via ISP #2 and you detect that using your TLS host rule, it is too late to reroute that to ISP #1.
Depending on how you do the rerouting, the connection will either fail or it will complete via ISP #2 (and only the next connection will be rerouted).
telecomnetwork2022
Re: ISP & SPEEDTEST
Mon Jan 02, 2023 4:59 pm
I understand you but in case we can move the rule in up it will have priority to excute by server before other rule is that right ?
mkx
Re: ISP & SPEEDTEST
Mon Jan 02, 2023 8:30 pm
No. The way TCP works (TLS is no exception) is this:
  1. client sends TCP packet without payload, only meaningful thing is SYN flag
  2. server sends reply without any payload. The only meaningful thing are SYN+ACK flags
  3. client sends anotger packet. Most often is again without payload, only ACK flag. Sometimes this packet carries some payliad, but not often
  4. client sends payload, which in TLS case carries SNI (in v1.2 and earlier it's plaintext, in v1.3 it's encrypted as well)
  5. server sends TLS feedback
  6. data exchange starts
So only in step #4 it's possible to re-route request via another ISP (if that's what you want) and that's waaay too late to "save" the connection ... and server will drop connection (because change in SRC address will be seen as invalid connection from the new SRC address). And this really doesn't depend on rule priority on router/firewall ...
If address list updating works as intended, the next connection attempt will be routed towards ISP#2 already in step #1 and connection will eventually succeed.
telecomnetwork2022
Re: ISP & SPEEDTEST
Tue Jan 03, 2023 11:16 am
Thank for everybody What matters is that my issue has been resolved
pe1chl
Re: ISP & SPEEDTEST
Tue Jan 03, 2023 12:34 pm
We don't think so. Either you had no issue at all, or it has not been (completely) resolved. Because that is impossible.
telecomnetwork2022
Re: ISP & SPEEDTEST
Tue Jan 03, 2023 3:45 pm
Can you Explaine me what the different between pcc load balance Firewall Mangle Rule and the Rule i use to Reroute Connection to onother ISP
the tow Rule = Same Resault but in pcc load balance the route will go automatic \
tow rule have mark connections and prerouting
and in Reroute Connection will go manual
telecomnetwork2022
Re: ISP & SPEEDTEST
Tue Jan 03, 2023 10:02 pm
CAN YOU SEE THIS VIDEO ?
https://youtu.be/XuTuIonXsns
ganggumalam
Re: ISP
Tue Jan 31, 2023 11:46 pm
if you want to rename ISP on speedtest you view https://damastik.com/change-mikrotik-is ... speedtest/
Users browsing this forum: anav, DanMos79, Minions70, raiser, thobias and 96 guests
