lapsio
Long time Member
Long time Member
Difference between rev 1 and rev 2 of CRS317?
Sat Dec 31, 2022 5:20 pm
Hi, today my 4th CRS317 arrived and I noticed it's marked as R2. I checked my other CRS317 switches and one of them is also R2 while two other are non-R2. What was difference between revision 1 and revision 2 of CRS317?
Maggiore81
Trainer
Trainer
Re: Difference between rev 1 and rev 2 of CRS317?
Wed Feb 15, 2023 10:17 pm
you should ask mikrotik direct via mail and then post here the info.
dot02
Tue Feb 28, 2023 5:19 pm
Did you get a feedback from them yet?
pcunite
Thu Mar 02, 2023 1:30 am
MikroTik and other vendors I think issue a revision for any change. It is not meant to indicate an improvement. So, another supplier was used for the capacitors, or different fans was sourced from a different company, etc.
Users browsing this forum: Bing [Bot] and 51 guests
