admin1606
management frame protection
Mon Jan 02, 2023 3:37 am
i have rb951ui-2hnd and i wanted to configure management protection on security profiles , the problem is when i choose ruqired and set the key , my windows laptop or my android device can't connect to the network , my android devices and my windows already support protected management frames
can any body help me ??
anav
Re: management frame protection
Tue Jan 03, 2023 1:03 am
Sorry never heard of management protection frames........... Is that some setting?
Why is it required,,,,,, no reasons provided.
Typically All smart devices are on a management subnet and usually in conjuction with vlans.
Vlans make sense when dealing with multiple wifi networks required even just two home and guest.
admin1606
Tue Jan 03, 2023 1:10 am
i attach an image
bpwl
Re: management frame protection  [SOLVED]
Tue Jan 03, 2023 1:39 am
RouterOS wifi implementation has many features that are not fully documented.
In most cases reading the RFC's (IEEE 802.11w-2009) or the big-player (eg Cisco) documentation has more information. Like: https://www.cisco.com/c/en/us/support/d ... -acce.html
Management frame protection is to protect the AP-client connection from disassociation by some (malicious) other device. https://en.wikipedia.org/wiki/Wi-Fi_dea ... ion_attack
That forced disassociation gives denial of service and is sometimes used to have more associations that can then be sniffed and analysed.
On MT setting frame protection to allow works fine with all connections.
With frame protection set to required, some connections fail, if the secret is not set, but even if the shared secret is correct.
Just tested shortly between MT devices in PtP, and now the setting stays on 'allowed' until further need.
MT docs say ....
RicSan
Tue Aug 15, 2023 10:01 am
I would also like to use the frame protection on a CAPsMAN environment.
Some devices are beeing attacked via a deauth device I guess and I want to use the frame protection on the HAPac devices beeing managed via CAPsMAN.
As the setting is not present in the capsman security profiles, I'd like to know how I can protect from this kind of attacks.
Users browsing this forum: ips and 36 guests
