ROBPER
ZeroTier private moons - roots
Mon Jan 02, 2023 2:02 pm
Dear all,
since July 2022, I succesfully configured in bridge mode my ZeroTier network on:
* DESKTOP
* LAPTOP
* wAP R AC running RouterOS 7.4
I'm also using two VM instances, with different public IP address, running ZeroTier version 1.10.2. (Op Sys == Ubuntu).
These two VM act a private ROOT SERVERS only (as described here https://docs.zerotier.com/zerotier/moons/);
Adding my private moons ID to clients in Windows PC and Linux, using the "zerotier-cli orbit" command followed by the two MOON_ID, works as expected, adding the moons to the peers list as attached image.
Question: in RouterOS 7.4, is there a way or a specific command to add private root servers ID, in order to the ZeroTier client to have and use them in the list of peers ?
Thank You
Roberto
richinuk
Re: ZeroTier private moons - roots
Wed Jan 25, 2023 3:01 am
+1. Also interested in this feature enhancement.
Larsa
Wed Jan 25, 2023 11:30 am
Private Root Servers (aka moons) could possibly be implemented as a container services but I'm pretty sure MT won't incorporate it as a standard package. You can host a private root service on your own server or on a cloud services.
- https://docs.zerotier.com/zerotier/moons/
- https://www.zerotier.com/2021/07/20/zerotier-makes-running-private-cloud-storage-more-accessible-and-easier-to-use/
tiernano
Wed Jan 25, 2023 1:03 pm
IIRC, Mikrotik dont build the Zerotier package for Router Boards. Its done by Zerotier themselves... You might want to reach out to them on their twitter/mastodon accounts...
Larsa
Wed Jan 25, 2023 1:26 pm
Well, if you pay MT or ZeroTier Inc enough, I'm pretty sure they'd be willing to look into the possibility of implementing a root server that could _possibly_ fit inside a container. Otherwise, it's up to you to fix it. Be aware that you won't be able to use the standard ZeroTier apps and the administrative web interface using a private root server.
Anyway, back to @ROBPER original question. MT has most probably implemented the standard linux client using hardcoded settings specificallyfor the ZeroTier controllers thus needs to add a new interface to allow private ones.
ROBPER
Sat Feb 04, 2023 2:35 pm
Dear all, thank You for support and reply.
Regards
Roberto
Users browsing this forum: marek263 and 9 guests
