tmr
R11e-LTE support for RB951Ui-2HnD?
Mon Jan 02, 2023 4:44 pm
The R11e-LTE modem connected via usb is not detected as an LTE device (lte1) in RB951Ui-2HnD. At the same time, it is easily detected and works as LTE modem in the RB952Ui-5ac2nD-TC. Both running ROS 7.6.
I also tried to downgrade RB to version 6.49.7, it did not help, the modem is not detected as a LTE device.
Is there any way to run the R11e-LTE on RB951 the same way it works on RB952Ui?
RB951Ui-2HnD
[admin@MikroTik] > /system resource usb print
Columns: DEVICE, VENDOR, NAME, SPEED
# DEVICE  VENDOR                NAME        SPEED
0 1-0     Linux 5.6.3 ehci_hcd  RB400 EHCI    480
1 1-1                           R11e-LTE      480
[admin@MikroTik] > /port print
Columns: NAME, CHANNELS, BAUD-RATE
#  NAME  CHANNELS  BAUD-RATE
0  usb1         1     9600
RB952Ui-5ac2nD-TC
[code][admin@MikroTik] > /system resource usb print
1 1-1     MikroTik              R11e-LTE      480
0  usb1         1       9600
[admin@MikroTik] > /interface lte print
Flags: R - RUNNING
Columns: NAME, MTU, NETWORK-MODE, APN-PROFILES
#   NAME   MTU  NETWORK-MODE  APN-PROFILES
0 R lte1  1480  gsm           default
                3g
                lte
Users browsing this forum: A9691, Amazon [Bot], GuJack20, hatred, korg, mojojojo and 65 guests
