CrazyApe
Could add new queue tree: too many packet marks in system
Mon Jan 02, 2023 7:01 pm
Hello guys,
i bought new X86 shaper (8core xeon 4,7 ghz built pm supermicro mobo with STGN-I2S network cards) and then i installed fresh v7 and have a problem with error telling me I have too many packet marks in system when i want to add line 4505 in queue tree. There is maximum number of packet marks in ROS v7 set to 4,5k or what ?? On RoS v 6 i have 5k on my older x86_64 central shaper with 4 cores and no problems...
Thx
chechito
Re: Could add new queue tree: too many packet marks in system
Mon Jan 02, 2023 8:11 pm
i can only say two things
OMG
WTF
chechito
Mon Jan 02, 2023 8:12 pm
i suggest you consider another scheme
i have tested up to 30k simple queues OK so you have a possible alternative
CrazyApe
Tue Jan 03, 2023 8:58 am
Why omg WTF? I need to use QT not SQ :(
petrb
Thu Jan 05, 2023 9:23 pm
Hi, you can replikate issue using (tested on x86 and CCR1036)
:local MARK
:local OC3
:local OC4
:set MARK 1
:set OC3 1
:set OC4 1
for i from=1 to=6000 do={
   /ip firewall mangle add chain=postrouting src-address="192.168.$OC3.$OC4" action=mark-packet new-packet-mark=$MARK
   /ip firewall mangle add chain=prerouting src-address="192.168.$OC3.$OC4" action=mark-packet new-packet-mark=$MARK
   /queue/tree/add parent=global packet-mark=$MARK
    :set OC4 ($OC4 + 1)
    :set MARK ($MARK + 1)
    :if ( $OC4 = 254) do={
        :set OC3 ($OC3 + 1)
       :set OC4 1
result and system info:
[admin@MikroTik] /queue/tree> /system/script/run script2
failure: too many packet marks in system
[admin@MikroTik] /queue/tree> /system/resource/print
                   uptime: 22m48s
                  version: 7.6 (stable)
               build-time: Oct/17/2022 10:55:40
         factory-software: 7.1
              free-memory: 7.4GiB
             total-memory: 7.7GiB
                      cpu: Intel(R)
                cpu-count: 4
            cpu-frequency: 2105MHz
                 cpu-load: 3%
           free-hdd-space: 221.7GiB
          total-hdd-space: 221.7GiB
  write-sect-since-reboot: 257184
         write-sect-total: 257184
        architecture-name: x86_64
               board-name: x86
                 platform: MikroTik
petrb
Thu Jan 05, 2023 11:02 pm
ROS is not able to add more than 4095 /queue/tree elements with unique MARK matcher,
CrazyApe
Wed Jan 11, 2023 9:16 am
ROS 6 had no problem with this … why this step back in ros7?
hapi
Wed Feb 22, 2023 1:52 pm
same problem. wtf?
hapi
Tue Mar 21, 2023 10:05 pm
some solution?
BartoszP
Wed Mar 22, 2023 9:52 am
new version, new rules.
hapi
Wed Mar 22, 2023 6:49 pm
new version, worse features?
Users browsing this forum: Aska, Bing [Bot], Google [Bot], GoogleOther [Bot] and 210 guests
