Kelalatir
New Router cannot maintain OSPF Link: 5 seconds on, 5 seconds off
Tue Jan 03, 2023 10:53 am
Greetings Mikrotik Forum,
I've setup a new CCR1036-12G-4S router at a new office that is opening this month. I've created a GRE tunnel back to the main office router which seems to be stable and working properly. I'm attempting to use OSPF to share routes between the sites. The main office router is router ID 10.1.0.200. The new office is router ID 10.12.0.200. This issue is that on 10.1.0.200 the route back to the new office subnet, 10.12.0.0/16, stays up for 5 seconds, then drops for 5 seconds, comes back for 5 seconds, drops again for 5 seconds, etc. The new office router maintains all its routes full time, the issue appears to be one-way only.
My first thought is that this would be caused by a firewall at the new office. To test, I disabled every firewall rule that drops a packet. The issue was unaffected. This seems to rule out the firewall as the problem.
My next idea was that the issue was related to the GRE tunnel. I disabled the GRE tunnel and setup an LT2P tunnel between the two sites as a test. The L2TP tunnel established fine, but the OSPF issue is exactly the same on this tunnel. It only breaks one-way, and it goes 5 seconds on, 5 seconds off.
To confirm which router has the issue, I created an L2TP tunnel between the new office and a third router at a different site. The OSPF issue still exists on this tunnel, where the third router still drops the route for 5 seconds, then adds it back for 5 seconds. To me, this says the issue must be on the new office router. None of the other dozen routers in our network have ever experienced this issue, but this issue exists whenever I create a tunnel between this new office and another router.
I'm out of ideas why this might be happening, and I request help and the wisdom of the forum. Any help or ideas would be appreciated.
Here is my sanitized router config from the new office:
> export
# jan/03/2023 00:03:04 by RouterOS 7.6
# software id = T1T3-P70T
# model = CCR1036-12G-4S
# serial number =
add ingress-filtering=no name=Bridge vlan-filtering=yes
set [ find default-name=ether1 ] name="ether1 Fiber"
set [ find default-name=ether8 ] name="ether8 AP"
set [ find default-name=ether9 ] name="ether9 UPS"
set [ find default-name=ether10 ] name="ether10 SW"
set [ find default-name=ether11 ] name="ether11 SW"
/interface gre
add allow-fast-path=no local-address=XXX.YYY.118.75 name="GRE Tunnel" remote-address=AAA.BBB.78.2
/interface vlan
add comment=VLAN66 interface=Bridge name=VLAN66 vlan-id=66
add name=WAN
add name=LAN
/interface lte apn
/ip dhcp-server option
add code=66 name="Phone Provisioning" value="s'10.2.4.2'"
/ip ipsec profile
set [ find default=yes ] dh-group=modp2048 enc-algorithm=aes-256 hash-algorithm=sha512
/ip ipsec proposal
set [ find default=yes ] auth-algorithms=sha512 enc-algorithms=aes-256-cbc pfs-group=modp2048
add name=dhcp_pool3 ranges=10.12.1.0/24
add name=dhcp_pool4 ranges=192.168.12.2-192.168.12.254
add address-pool=dhcp_pool3 interface=Bridge name=dhcp1
add address-pool=dhcp_pool4 interface=VLAN66 name=dhcp2
/port
set 0 name=serial0
set 1 name=serial1
/routing id
add disabled=no id=10.12.0.200 name=YR-Judicial-Court select-dynamic-id=""
/routing ospf instance
add disabled=no name=OSPF-IPv4 router-id=YR-Judicial-Court
/routing ospf area
add disabled=no instance=OSPF-IPv4 name=backbone
add bridge=Bridge ingress-filtering=no interface=ether3
add bridge=Bridge ingress-filtering=no interface=ether4
add bridge=Bridge ingress-filtering=no interface=ether5
add bridge=Bridge ingress-filtering=no interface=ether6
add bridge=Bridge ingress-filtering=no interface=ether7
add bridge=Bridge ingress-filtering=no interface="ether8 AP"
add bridge=Bridge ingress-filtering=no interface="ether9 UPS"
add bridge=Bridge ingress-filtering=no interface="ether10 SW"
add bridge=Bridge ingress-filtering=no interface="ether11 SW"
/ip settings
set max-neighbor-entries=8192
/ipv6 settings
/interface bridge vlan
add bridge=Bridge comment=VLAN66 tagged="ether8 AP,Bridge" vlan-ids=66
add bridge=Bridge comment=VLAN1 untagged="ether8 AP,Bridge" vlan-ids=1
add interface="ether1 Fiber" list=WAN
add interface=Bridge list=LAN
/interface ovpn-server server
set auth=sha1,md5
add address=10.12.0.200/16 interface=Bridge network=10.12.0.0
add address=172.17.12.2/30 interface="GRE Tunnel" network=172.17.12.0
add address=192.168.12.1/24 interface=VLAN66 network=192.168.12.0
/ip dhcp-client
add address=10.12.0.0/16 dhcp-option="Phone Provisioning" dns-server=10.1.0.1,10.1.0.33,10.2.0.1,1.1.1.1 gateway=10.12.0.200
add address=192.168.12.0/24 dns-server=8.8.8.8,8.8.4.4 gateway=192.168.12.1
set servers=10.1.0.33,10.1.0.1
/ip firewall address-list
add address=10.0.0.0/12 comment="Network safe" list=safe
add address=XXX.YYY.118.11 comment="Yreka Clinic IP for VPN Access" list=safe
add address=AAA.BBB.78.0/29 comment="Allow Access from HC Data Center Public IPs" list=safe
add address=AAA.BBB.78.8/29 comment="Allow Access from HC Data Center Public IPs" list=safe
add address=192.168.18.0/24 comment="Network safe" list=safe
add address=162.247.42.203 comment="CIO remote access" list=safe
add address=AAA.BBB.78.43 comment="Network safe" list=safe
add address=159.148.147.204 comment="download.mikrotik.com for router updates" list=safe
add address=159.148.172.226 comment="download.mikrotik.com for router updates" list=safe
add address=192.168.20.0/24 comment="Network safe" list=safe
add address=192.168.22.0/24 comment="Network safe" list=safe
add address=192.168.23.0/24 comment="Network safe" list=safe
add address=172.16.0.0/12 comment="Network safe" list=safe
add action=drop chain=forward comment="Firewall vlan66 from private network" in-interface=VLAN66 out-interface="!ether1 Fiber"
add action=drop chain=forward comment="Firewall vlan66 from private network" in-interface="!ether1 Fiber" out-interface=VLAN66
add action=accept chain=forward comment="Allow Established and Related Connections" connection-state=established,related
add action=drop chain=forward comment="Drop invalid connections" connection-state=invalid
add action=accept chain=forward comment="Allow addresses in safe list to forward" src-address-list=safe
add action=accept chain=forward comment="Allow local devices to forward" in-interface=Bridge
add action=accept chain=forward comment="Allow Guestnet out to internet." in-interface=VLAN66 out-interface="ether1 Fiber"
add action=drop chain=forward comment="Block all remaining forwards (last forward rule)" log-prefix="Drop Forward: "
add action=accept chain=input comment="Allow Established and Related Connections" connection-state=established,related
add action=drop chain=input comment="Drop invalid connections" connection-state=invalid
add action=drop chain=input comment="If Vlan 66 tries to talk to the router itself drop it" in-interface=VLAN66
add action=accept chain=input comment="Allow local devices access to this router" in-interface=Bridge
add action=accept chain=input comment="Allow safe list" src-address-list=safe
add action=drop chain=input comment="Block all remaining input (last input rule)" log-prefix="Drop input: "
add action=accept chain=srcnat comment="Don't NAT if not going to Fiber Internet" out-interface="!ether1 Fiber"
add action=masquerade chain=srcnat comment="NAT for public internet" out-interface="ether1 Fiber"
add comment="Static route to public IP's for VPN Tunnel" disabled=no distance=1 dst-address=137.0.0.0/8 gateway=XXX.YYY.118.65 pref-src="" routing-table=main scope=30 \
    suppress-hw-offload=no target-scope=10
/routing ospf interface-template
add area=backbone disabled=no interfaces=Bridge networks=10.12.0.0/16
add area=backbone disabled=no interfaces="GRE Tunnel" networks=172.17.12.0/30 type=ptp
/system identity
set name=Yr-Judicial-Court
/system logging
add action=disk disabled=yes topics=firewall
add action=netevents topics=critical
add disabled=yes topics=ospf
/system ntp client
set enabled=yes
/system ntp client servers
add address=10.1.0.1
add address=0.pool.ntp.org
/tool graphing interface
add interface="GRE Tunnel"
Here is a sample of the OSPF log output on the 10.1.0.200 router:
Jan/02/2023 22:22:22 route,ospf,packet ospf-instance-1 { version: 2 router-id: 10.1.0.200 } backbone { 0.0.0.0 } interface { p2p 172.17.12.1%HC YR Judicial  } neighbor { router-id: 10.12.0.200 state: Full } hello
Jan/02/2023 22:22:23 route,ospf,packet ospf-instance-1 { version: 2 router-id: 10.1.0.200 } backbone { 0.0.0.0 } interface { p2p 172.17.12.1%HC YR Judicial  } send hello
Jan/02/2023 22:22:23 route,ospf,debug ospf-instance-1 { version: 2 router-id: 10.1.0.200 } backbone { 0.0.0.0 } interface { p2p 172.17.61.2%HC-YR-Fibers } neighbor { router-id: 10.2.0.200 state: Full } update router 10.12.0.200 10.12.0.200 seq 0x80020f17 age 16 csum 0x3b95 Older with seq 0x80020f18 age 13 csum 0xedd2
Jan/02/2023 22:22:23 route,ospf,debug ospf-instance-1 { version: 2 router-id: 10.1.0.200 } backbone { 0.0.0.0 } lsa { router originator: 10.12.0.200 id: 10.12.0.200 seq: 0x80020f17 csum: 0x3b95 } received update
Jan/02/2023 22:22:23 route,ospf,debug ospf-instance-1 { version: 2 router-id: 10.1.0.200 } calc schedule
Jan/02/2023 22:22:23 route,ospf,debug ospf-instance-1 { version: 2 router-id: 10.1.0.200 } backbone { 0.0.0.0 } lsa { router originator: 10.12.0.200 id: 10.12.0.200 seq: 0x80020f18 csum: 0xedd2 } schedule decay age: 3587
Jan/02/2023 22:22:23 route,ospf,debug ospf-instance-1 { version: 2 router-id: 10.1.0.200 } backbone { 0.0.0.0 } lsa { router originator: 10.12.0.200 id: 10.12.0.200 seq: 0x80020f18 csum: 0xedd2 } flooding
Jan/02/2023 22:22:23 route,ospf,packet ospf-instance-1 { version: 2 router-id: 10.1.0.200 } backbone { 0.0.0.0 } interface { p2p 172.17.12.1%HC YR Judicial  } flood LS update
Jan/02/2023 22:22:23 route,ospf,packet ospf-instance-1 { version: 2 router-id: 10.1.0.200 } backbone { 0.0.0.0 } interface { p2p 172.17.12.1%HC YR Judicial  } neighbor { router-id: 10.12.0.200 state: Full } receive LS update
Jan/02/2023 22:22:23 route,ospf,debug ospf-instance-1 { version: 2 router-id: 10.1.0.200 } backbone { 0.0.0.0 } interface { p2p 172.17.12.1%HC YR Judicial  } neighbor { router-id: 10.12.0.200 state: Full } update router 10.12.0.200 10.12.0.200 seq 0x80020f18 age 13 csum 0xedd2 Older with seq 0x80020f19 age 1 csum 0x3797
Jan/02/2023 22:22:24 route,ospf,debug ospf-instance-1 { version: 2 router-id: 10.1.0.200 } calc start
Jan/02/2023 22:22:24 route,ospf,debug ospf-instance-1 { version: 2 router-id: 10.1.0.200 } backbone { 0.0.0.0 } calc spt
Jan/02/2023 22:22:24 route,ospf,packet ospf-instance-1 { version: 2 router-id: 10.1.0.200 } backbone { 0.0.0.0 } interface { p2p 172.17.61.2%HC-YR-Fibers } send 1 delayed ACKs
Jan/02/2023 22:22:24 route,ospf,debug ospf-instance-1 { version: 2 router-id: 10.1.0.200 } process summaries for ospf-instance-1 { version: 2 router-id: 10.1.0.200 } backbone { 0.0.0.0 }
Jan/02/2023 22:22:24 route,ospf,debug ospf-instance-1 { version: 2 router-id: 10.1.0.200 } process externals
Jan/02/2023 22:22:24 route,ospf,debug ospf-instance-1 { version: 2 router-id: 10.1.0.200 } install routes
Jan/02/2023 22:22:24 route,ospf,debug ospf-instance-1 { version: 2 router-id: 10.1.0.200 } post process summaries
Jan/02/2023 22:22:24 route,ospf,debug ospf-instance-1 { version: 2 router-id: 10.1.0.200 } calc done
Jan/02/2023 22:22:24 route,ospf,packet ospf-instance-1 { version: 2 router-id: 10.1.0.200 } backbone { 0.0.0.0 } interface { p2p 172.17.21.1%Mech Shop L2TP } neighbor { router-id: 192.168.21.1 state: Full } received 1 LS ACKs
Jan/02/2023 22:22:26 route,ospf,packet ospf-instance-1 { version: 2 router-id: 10.1.0.200 } backbone { 0.0.0.0 } interface { p2p 172.17.61.2%HC-YR-Fibers } send hello
Jan/02/2023 22:22:27 route,ospf,packet ospf-instance-1 { version: 2 router-id: 10.1.0.200 } backbone { 0.0.0.0 } interface { p2p 172.17.61.2%HC-YR-Fibers } neighbor { router-id: 10.2.0.200 state: Full } hello
Jan/02/2023 22:22:28 route,ospf,packet ospf-instance-1 { version: 2 router-id: 10.1.0.200 } backbone { 0.0.0.0 } interface { p2p 172.17.12.1%HC YR Judicial  } neighbor { router-id: 10.12.0.200 state: Full } receive LS update
Jan/02/2023 22:22:28 route,ospf,debug ospf-instance-1 { version: 2 router-id: 10.1.0.200 } backbone { 0.0.0.0 } interface { p2p 172.17.12.1%HC YR Judicial  } neighbor { router-id: 10.12.0.200 state: Full } update router 10.12.0.200 10.12.0.200 seq 0x80020f18 age 18 csum 0xedd2 Older with seq 0x80020f19 age 6 csum 0x3797
Jan/02/2023 22:22:28 route,ospf,debug ospf-instance-1 { version: 2 router-id: 10.1.0.200 } backbone { 0.0.0.0 } lsa { router originator: 10.12.0.200 id: 10.12.0.200 seq: 0x80020f18 csum: 0xedd2 } received update
Jan/02/2023 22:22:28 route,ospf,debug ospf-instance-1 { version: 2 router-id: 10.1.0.200 } calc schedule
Jan/02/2023 22:22:28 route,ospf,debug ospf-instance-1 { version: 2 router-id: 10.1.0.200 } backbone { 0.0.0.0 } lsa { router originator: 10.12.0.200 id: 10.12.0.200 seq: 0x80020f19 csum: 0x3797 } schedule decay age: 3594
Jan/02/2023 22:22:28 route,ospf,debug ospf-instance-1 { version: 2 router-id: 10.1.0.200 } backbone { 0.0.0.0 } lsa { router originator: 10.12.0.200 id: 10.12.0.200 seq: 0x80020f19 csum: 0x3797 } flooding
Jan/02/2023 22:22:28 route,ospf,packet ospf-instance-1 { version: 2 router-id: 10.1.0.200 } backbone { 0.0.0.0 } interface { p2p 172.17.21.1%Mech Shop L2TP } flood LS update
Jan/02/2023 22:22:28 route,ospf,packet ospf-instance-1 { version: 2 router-id: 10.1.0.200 } backbone { 0.0.0.0 } interface { p2p 172.17.61.2%HC-YR-Fibers } flood LS update
Jan/02/2023 22:22:29 route,ospf,packet ospf-instance-1 { version: 2 router-id: 10.1.0.200 } backbone { 0.0.0.0 } interface { p2p 172.17.21.1%Mech Shop L2TP } send hello
Jan/02/2023 22:22:29 route,ospf,packet ospf-instance-1 { version: 2 router-id: 10.1.0.200 } backbone { 0.0.0.0 } interface { p2p 172.17.12.1%HC YR Judicial  } send 1 delayed ACKs
Jan/02/2023 22:22:29 route,ospf,packet ospf-instance-1 { version: 2 router-id: 10.1.0.200 } backbone { 0.0.0.0 } interface { p2p 172.17.61.2%HC-YR-Fibers } neighbor { router-id: 10.2.0.200 state: Full } received 1 LS ACKs
Jan/02/2023 22:22:29 route,ospf,debug ospf-instance-1 { version: 2 router-id: 10.1.0.200 } calc start
Jan/02/2023 22:22:29 route,ospf,debug ospf-instance-1 { version: 2 router-id: 10.1.0.200 } backbone { 0.0.0.0 } calc spt
Jan/02/2023 22:22:29 route,ospf,debug ospf-instance-1 { version: 2 router-id: 10.1.0.200 } process summaries for ospf-instance-1 { version: 2 router-id: 10.1.0.200 } backbone { 0.0.0.0 }
Jan/02/2023 22:22:29 route,ospf,debug ospf-instance-1 { version: 2 router-id: 10.1.0.200 } process externals
Jan/02/2023 22:22:29 route,ospf,debug ospf-instance-1 { version: 2 router-id: 10.1.0.200 } install routes
Jan/02/2023 22:22:29 route,ospf,debug ospf-instance-1 { version: 2 router-id: 10.1.0.200 } post process summaries
Jan/02/2023 22:22:29 route,ospf,debug ospf-instance-1 { version: 2 router-id: 10.1.0.200 } calc done
Jan/02/2023 22:22:29 route,ospf,packet ospf-instance-1 { version: 2 router-id: 10.1.0.200 } backbone { 0.0.0.0 } interface { p2p 172.17.21.1%Mech Shop L2TP } neighbor { router-id: 192.168.21.1 state: Full } received 1 LS ACKs
Jan/02/2023 22:22:32 route,ospf,packet ospf-instance-1 { version: 2 router-id: 10.1.0.200 } backbone { 0.0.0.0 } interface { p2p 172.17.21.1%Mech Shop L2TP } neighbor { router-id: 192.168.21.1 state: Full } hello
Jan/02/2023 22:22:32 route,ospf,packet ospf-instance-1 { version: 2 router-id: 10.1.0.200 } backbone { 0.0.0.0 } interface { p2p 172.17.12.1%HC YR Judicial  } neighbor { router-id: 10.12.0.200 state: Full } hello
Jan/02/2023 22:22:33 route,ospf,packet ospf-instance-1 { version: 2 router-id: 10.1.0.200 } backbone { 0.0.0.0 } interface { p2p 172.17.12.1%HC YR Judicial  } send hello
Jan/02/2023 22:22:33 route,ospf,packet ospf-instance-1 { version: 2 router-id: 10.1.0.200 } backbone { 0.0.0.0 } interface { p2p 172.17.61.2%HC-YR-Fibers } neighbor { router-id: 10.2.0.200 state: Full } receive LS update
Jan/02/2023 22:22:33 route,ospf,debug ospf-instance-1 { version: 2 router-id: 10.1.0.200 } backbone { 0.0.0.0 } interface { p2p 172.17.61.2%HC-YR-Fibers } neighbor { router-id: 10.2.0.200 state: Full } update router 10.12.0.200 10.12.0.200 seq 0x80020f19 age 11 csum 0x3797 Older with seq 0x80020f1a age 8 csum 0xe9d4
Jan/02/2023 22:22:33 route,ospf,debug ospf-instance-1 { version: 2 router-id: 10.1.0.200 } backbone { 0.0.0.0 } lsa { router originator: 10.12.0.200 id: 10.12.0.200 seq: 0x80020f19 csum: 0x3797 } received update
Jan/02/2023 22:22:33 route,ospf,debug ospf-instance-1 { version: 2 router-id: 10.1.0.200 } calc schedule
Jan/02/2023 22:22:33 route,ospf,debug ospf-instance-1 { version: 2 router-id: 10.1.0.200 } backbone { 0.0.0.0 } lsa { router originator: 10.12.0.200 id: 10.12.0.200 seq: 0x80020f1a csum: 0xe9d4 } schedule decay age: 3592
Jan/02/2023 22:22:33 route,ospf,debug ospf-instance-1 { version: 2 router-id: 10.1.0.200 } backbone { 0.0.0.0 } lsa { router originator: 10.12.0.200 id: 10.12.0.200 seq: 0x80020f1a csum: 0xe9d4 } flooding
Jan/02/2023 22:22:34 route,ospf,packet ospf-instance-1 { version: 2 router-id: 10.1.0.200 } backbone { 0.0.0.0 } interface { p2p 172.17.12.1%HC YR Judicial  } flood LS update
Jan/02/2023 22:22:34 route,ospf,packet ospf-instance-1 { version: 2 router-id: 10.1.0.200 } backbone { 0.0.0.0 } interface { p2p 172.17.21.1%Mech Shop L2TP } flood LS update
Jan/02/2023 22:22:34 route,ospf,packet ospf-instance-1 { version: 2 router-id: 10.1.0.200 } backbone { 0.0.0.0 } interface { p2p 172.17.12.1%HC YR Judicial  } neighbor { router-id: 10.12.0.200 state: Full } receive LS update
Jan/02/2023 22:22:34 route,ospf,debug ospf-instance-1 { version: 2 router-id: 10.1.0.200 } backbone { 0.0.0.0 } interface { p2p 172.17.12.1%HC YR Judicial  } neighbor { router-id: 10.12.0.200 state: Full } update router 10.12.0.200 10.12.0.200 seq 0x80020f1a age 8 csum 0xe9d4 Older with seq 0x80020f1b age 1 csum 0x3399
Jan/02/2023 22:22:34 route,ospf,packet ospf-instance-1 { version: 2 router-id: 10.1.0.200 } backbone { 0.0.0.0 } interface { p2p 172.17.61.2%HC-YR-Fibers } send 1 delayed ACKs
Jan/02/2023 22:22:34 route,ospf,debug ospf-instance-1 { version: 2 router-id: 10.1.0.200 } calc start
Jan/02/2023 22:22:34 route,ospf,debug ospf-instance-1 { version: 2 router-id: 10.1.0.200 } backbone { 0.0.0.0 } calc spt
Jan/02/2023 22:22:34 route,ospf,debug ospf-instance-1 { version: 2 router-id: 10.1.0.200 } process summaries for ospf-instance-1 { version: 2 router-id: 10.1.0.200 } backbone { 0.0.0.0 }
Jan/02/2023 22:22:34 route,ospf,debug ospf-instance-1 { version: 2 router-id: 10.1.0.200 } process externals
Jan/02/2023 22:22:34 route,ospf,debug ospf-instance-1 { version: 2 router-id: 10.1.0.200 } install routes
Jan/02/2023 22:22:34 route,ospf,debug ospf-instance-1 { version: 2 router-id: 10.1.0.200 } post process summaries
Jan/02/2023 22:22:34 route,ospf,debug ospf-instance-1 { version: 2 router-id: 10.1.0.200 } calc done
Jan/02/2023 22:22:34 route,ospf,packet ospf-instance-1 { version: 2 router-id: 10.1.0.200 } backbone { 0.0.0.0 } interface { p2p 172.17.21.1%Mech Shop L2TP } neighbor { router-id: 192.168.21.1 state: Full } received 1 LS ACKs
Here is a sample from the OSPF log on the 10.12.0.200 router:
Jan/03/2023 00:48:07 route,ospf,packet OSPF-IPv4 { version: 2 router-id: 10.12.0.200 } backbone { 0.0.0.0 } interface { p2p 172.17.12.2%HC YR Judicial  } neighbor { router-id: 10.1.0.200 state: Full } hello
Jan/03/2023 00:48:10 route,ospf,packet OSPF-IPv4 { version: 2 router-id: 10.12.0.200 } backbone { 0.0.0.0 } interface { p2p 172.17.12.2%HC YR Judicial  } neighbor { router-id: 10.1.0.200 state: Full } receive LS update
Jan/03/2023 00:48:10 route,ospf,debug OSPF-IPv4 { version: 2 router-id: 10.12.0.200 } backbone { 0.0.0.0 } interface { p2p 172.17.12.2%HC YR Judicial  } neighbor { router-id: 10.1.0.200 state: Full } update router 10.12.0.200 10.12.0.200 seq 0x800213ab age 9 csum 0x632 Older with seq 0x800213ac age 14 csum 0xb86f
Jan/03/2023 00:48:10 route,ospf,debug OSPF-IPv4 { version: 2 router-id: 10.12.0.200 } backbone { 0.0.0.0 } lsa { router originator: 10.12.0.200 id: 10.12.0.200 seq: 0x800213ab csum: 0x632 } originator promote to 0x800213ac
Jan/03/2023 00:48:10 route,ospf,debug OSPF-IPv4 { version: 2 router-id: 10.12.0.200 } backbone { 0.0.0.0 } lsa { router originator: 10.12.0.200 id: 10.12.0.200 seq: 0x800213ad csum: 0x234 } flooding
Jan/03/2023 00:48:10 route,ospf,packet OSPF-IPv4 { version: 2 router-id: 10.12.0.200 } backbone { 0.0.0.0 } interface { p2p 172.17.12.2%HC YR Judicial  } flood LS update
Jan/03/2023 00:48:14 route,ospf,packet OSPF-IPv4 { version: 2 router-id: 10.12.0.200 } backbone { 0.0.0.0 } interface { p2p 172.17.12.2%HC YR Judicial  } send hello
Jan/03/2023 00:48:15 route,ospf,packet OSPF-IPv4 { version: 2 router-id: 10.12.0.200 } backbone { 0.0.0.0 } interface { p2p 172.17.12.2%HC YR Judicial  } neighbor { router-id: 10.1.0.200 state: Full } receive LS update
Jan/03/2023 00:48:15 route,ospf,debug OSPF-IPv4 { version: 2 router-id: 10.12.0.200 } backbone { 0.0.0.0 } interface { p2p 172.17.12.2%HC YR Judicial  } neighbor { router-id: 10.1.0.200 state: Full } update router 10.12.0.200 10.12.0.200 seq 0x800213ad age 0 csum 0x234 Newer with seq 0x800213ac age 19 csum 0xb86f
Jan/03/2023 00:48:15 route,ospf,packet OSPF-IPv4 { version: 2 router-id: 10.12.0.200 } backbone { 0.0.0.0 } interface { p2p 172.17.12.2%HC YR Judicial  } neighbor { router-id: 10.1.0.200 state: Full } retransmit LS updates
Jan/03/2023 00:48:16 route,ospf,packet OSPF-IPv4 { version: 2 router-id: 10.12.0.200 } backbone { 0.0.0.0 } interface { p2p 172.17.12.2%HC YR Judicial  } neighbor { router-id: 10.1.0.200 state: Full } received 1 LS ACKs
Jan/03/2023 00:48:16 route,ospf,packet OSPF-IPv4 { version: 2 router-id: 10.12.0.200 } backbone { 0.0.0.0 } interface { broadcast 10.12.0.200%Bridge } send hello
Jan/03/2023 00:48:17 route,ospf,packet OSPF-IPv4 { version: 2 router-id: 10.12.0.200 } backbone { 0.0.0.0 } interface { p2p 172.17.12.2%HC YR Judicial  } neighbor { router-id: 10.1.0.200 state: Full } hello
Jan/03/2023 00:48:20 route,ospf,packet OSPF-IPv4 { version: 2 router-id: 10.12.0.200 } backbone { 0.0.0.0 } interface { p2p 172.17.12.2%HC YR Judicial  } neighbor { router-id: 10.1.0.200 state: Full } receive LS update
Jan/03/2023 00:48:20 route,ospf,debug OSPF-IPv4 { version: 2 router-id: 10.12.0.200 } backbone { 0.0.0.0 } interface { p2p 172.17.12.2%HC YR Judicial  } neighbor { router-id: 10.1.0.200 state: Full } update router 10.12.0.200 10.12.0.200 seq 0x800213ad age 5 csum 0x234 Older with seq 0x800213ae age 9 csum 0xb471
Jan/03/2023 00:48:20 route,ospf,debug OSPF-IPv4 { version: 2 router-id: 10.12.0.200 } backbone { 0.0.0.0 } lsa { router originator: 10.12.0.200 id: 10.12.0.200 seq: 0x800213ad csum: 0x234 } originator promote to 0x800213ae
Jan/03/2023 00:48:20 route,ospf,debug OSPF-IPv4 { version: 2 router-id: 10.12.0.200 } backbone { 0.0.0.0 } lsa { router originator: 10.12.0.200 id: 10.12.0.200 seq: 0x800213af csum: 0xfd36 } flooding
Jan/03/2023 00:48:20 route,ospf,packet OSPF-IPv4 { version: 2 router-id: 10.12.0.200 } backbone { 0.0.0.0 } interface { p2p 172.17.12.2%HC YR Judicial  } flood LS update
Jan/03/2023 00:48:24 route,ospf,packet OSPF-IPv4 { version: 2 router-id: 10.12.0.200 } backbone { 0.0.0.0 } interface { p2p 172.17.12.2%HC YR Judicial  } send hello
Jan/03/2023 00:48:25 route,ospf,packet OSPF-IPv4 { version: 2 router-id: 10.12.0.200 } backbone { 0.0.0.0 } interface { p2p 172.17.12.2%HC YR Judicial  } neighbor { router-id: 10.1.0.200 state: Full } receive LS update
Jan/03/2023 00:48:25 route,ospf,debug OSPF-IPv4 { version: 2 router-id: 10.12.0.200 } backbone { 0.0.0.0 } interface { p2p 172.17.12.2%HC YR Judicial  } neighbor { router-id: 10.1.0.200 state: Full } update router 10.12.0.200 10.12.0.200 seq 0x800213af age 5 csum 0xfd36 Newer with seq 0x800213ae age 14 csum 0xb471
Jan/03/2023 00:48:25 route,ospf,packet OSPF-IPv4 { version: 2 router-id: 10.12.0.200 } backbone { 0.0.0.0 } interface { p2p 172.17.12.2%HC YR Judicial  } neighbor { router-id: 10.1.0.200 state: Full } retransmit LS updates
Jan/03/2023 00:48:25 route,ospf,packet OSPF-IPv4 { version: 2 router-id: 10.12.0.200 } backbone { 0.0.0.0 } interface { p2p 172.17.12.2%HC YR Judicial  } neighbor { router-id: 10.1.0.200 state: Full } received 1 LS ACKs
Jan/03/2023 00:48:26 route,ospf,packet OSPF-IPv4 { version: 2 router-id: 10.12.0.200 } backbone { 0.0.0.0 } interface { p2p 172.17.12.2%HC YR Judicial  } neighbor { router-id: 10.1.0.200 state: Full } received 0 LS ACKs
Jan/03/2023 00:48:26 route,ospf,packet OSPF-IPv4 { version: 2 router-id: 10.12.0.200 } backbone { 0.0.0.0 } interface { broadcast 10.12.0.200%Bridge } send hello
Jan/03/2023 00:48:27 route,ospf,packet OSPF-IPv4 { version: 2 router-id: 10.12.0.200 } backbone { 0.0.0.0 } interface { p2p 172.17.12.2%HC YR Judicial  } neighbor { router-id: 10.1.0.200 state: Full } hello
Jan/03/2023 00:48:34 route,ospf,packet OSPF-IPv4 { version: 2 router-id: 10.12.0.200 } backbone { 0.0.0.0 } interface { p2p 172.17.12.2%HC YR Judicial  } send hello
Jan/03/2023 00:48:34 route,ospf,packet OSPF-IPv4 { version: 2 router-id: 10.12.0.200 } backbone { 0.0.0.0 } interface { p2p 172.17.12.2%HC YR Judicial  } neighbor { router-id: 10.1.0.200 state: Full } receive LS update
Jan/03/2023 00:48:34 route,ospf,debug OSPF-IPv4 { version: 2 router-id: 10.12.0.200 } backbone { 0.0.0.0 } interface { p2p 172.17.12.2%HC YR Judicial  } neighbor { router-id: 10.1.0.200 state: Full } update router 192.168.15.1 192.168.15.1 seq 0x800022c1 age 1795 csum 0x5014 Older with seq 0x800022c2 age 3 csum 0x4e15
Jan/03/2023 00:48:34 route,ospf,debug OSPF-IPv4 { version: 2 router-id: 10.12.0.200 } backbone { 0.0.0.0 } lsa { router originator: 192.168.15.1 id: 192.168.15.1 seq: 0x800022c1 csum: 0x5014 } received refresh
Jan/03/2023 00:48:34 route,ospf,debug OSPF-IPv4 { version: 2 router-id: 10.12.0.200 } backbone { 0.0.0.0 } lsa { router originator: 192.168.15.1 id: 192.168.15.1 seq: 0x800022c2 csum: 0x4e15 } schedule decay age: 3597
Jan/03/2023 00:48:34 route,ospf,debug OSPF-IPv4 { version: 2 router-id: 10.12.0.200 } backbone { 0.0.0.0 } lsa { router originator: 192.168.15.1 id: 192.168.15.1 seq: 0x800022c2 csum: 0x4e15 } flooding
Jan/03/2023 00:48:35 route,ospf,packet OSPF-IPv4 { version: 2 router-id: 10.12.0.200 } backbone { 0.0.0.0 } interface { p2p 172.17.12.2%HC YR Judicial  } send 1 delayed ACKs
Jan/03/2023 00:48:35 route,ospf,packet OSPF-IPv4 { version: 2 router-id: 10.12.0.200 } backbone { 0.0.0.0 } interface { p2p 172.17.12.2%HC YR Judicial  } neighbor { router-id: 10.1.0.200 state: Full } receive LS update
Jan/03/2023 00:48:35 route,ospf,debug OSPF-IPv4 { version: 2 router-id: 10.12.0.200 } backbone { 0.0.0.0 } interface { p2p 172.17.12.2%HC YR Judicial  } neighbor { router-id: 10.1.0.200 state: Full } update router 10.12.0.200 10.12.0.200 seq 0x800213af age 9 csum 0xfd36 Older with seq 0x800213b0 age 13 csum 0xb073
Jan/03/2023 00:48:35 route,ospf,debug OSPF-IPv4 { version: 2 router-id: 10.12.0.200 } backbone { 0.0.0.0 } lsa { router originator: 10.12.0.200 id: 10.12.0.200 seq: 0x800213af csum: 0xfd36 } originator promote to 0x800213b0
Jan/03/2023 00:48:35 route,ospf,debug OSPF-IPv4 { version: 2 router-id: 10.12.0.200 } backbone { 0.0.0.0 } lsa { router originator: 10.12.0.200 id: 10.12.0.200 seq: 0x800213b1 csum: 0xf938 } flooding
Jan/03/2023 00:48:35 route,ospf,packet OSPF-IPv4 { version: 2 router-id: 10.12.0.200 } backbone { 0.0.0.0 } interface { p2p 172.17.12.2%HC YR Judicial  } flood LS update
Jan/03/2023 00:48:36 route,ospf,packet OSPF-IPv4 { version: 2 router-id: 10.12.0.200 } backbone { 0.0.0.0 } interface { broadcast 10.12.0.200%Bridge } send hello
Jan/03/2023 00:48:37 route,ospf,packet OSPF-IPv4 { version: 2 router-id: 10.12.0.200 } backbone { 0.0.0.0 } interface { p2p 172.17.12.2%HC YR Judicial  } neighbor { router-id: 10.1.0.200 state: Full } hello
Jan/03/2023 00:48:40 route,ospf,packet OSPF-IPv4 { version: 2 router-id: 10.12.0.200 } backbone { 0.0.0.0 } interface { p2p 172.17.12.2%HC YR Judicial  } neighbor { router-id: 10.1.0.200 state: Full } retransmit LS updates
Jan/03/2023 00:48:41 route,ospf,packet OSPF-IPv4 { version: 2 router-id: 10.12.0.200 } backbone { 0.0.0.0 } interface { p2p 172.17.12.2%HC YR Judicial  } neighbor { router-id: 10.1.0.200 state: Full } received 1 LS ACKs
Jan/03/2023 00:48:44 route,ospf,packet OSPF-IPv4 { version: 2 router-id: 10.12.0.200 } backbone { 0.0.0.0 } interface { p2p 172.17.12.2%HC YR Judicial  } send hello
Jan/03/2023 00:48:46 route,ospf,packet OSPF-IPv4 { version: 2 router-id: 10.12.0.200 } backbone { 0.0.0.0 } interface { broadcast 10.12.0.200%Bridge } send hello
Jan/03/2023 00:48:47 route,ospf,packet OSPF-IPv4 { version: 2 router-id: 10.12.0.200 } backbone { 0.0.0.0 } interface { p2p 172.17.12.2%HC YR Judicial  } neighbor { router-id: 10.1.0.200 state: Full } hello
Jan/03/2023 00:48:50 route,ospf,packet OSPF-IPv4 { version: 2 router-id: 10.12.0.200 } backbone { 0.0.0.0 } interface { p2p 172.17.12.2%HC YR Judicial  } neighbor { router-id: 10.1.0.200 state: Full } receive LS update
Jan/03/2023 00:48:50 route,ospf,debug OSPF-IPv4 { version: 2 router-id: 10.12.0.200 } backbone { 0.0.0.0 } interface { p2p 172.17.12.2%HC YR Judicial  } neighbor { router-id: 10.1.0.200 state: Full } update router 10.12.0.200 10.12.0.200 seq 0x800213b1 age 9 csum 0xf938 Older with seq 0x800213b2 age 14 csum 0xac75
Jan/03/2023 00:48:50 route,ospf,debug OSPF-IPv4 { version: 2 router-id: 10.12.0.200 } backbone { 0.0.0.0 } lsa { router originator: 10.12.0.200 id: 10.12.0.200 seq: 0x800213b1 csum: 0xf938 } originator promote to 0x800213b2
Jan/03/2023 00:48:50 route,ospf,debug OSPF-IPv4 { version: 2 router-id: 10.12.0.200 } backbone { 0.0.0.0 } lsa { router originator: 10.12.0.200 id: 10.12.0.200 seq: 0x800213b3 csum: 0xf53a } flooding
Jan/03/2023 00:48:50 route,ospf,packet OSPF-IPv4 { version: 2 router-id: 10.12.0.200 } backbone { 0.0.0.0 } interface { p2p 172.17.12.2%HC YR Judicial  } flood LS update
Thank you.
Kelalatir
Re: New Router cannot maintain OSPF Link: 5 seconds on, 5 seconds off
Fri Feb 17, 2023 10:23 pm
Mikrotik Support came through and helped us solve this issue. Apparently we had a duplicate router ID on our network, leftover on another Mikrotik router that previously had the same subnet we reused on our new router. Updating the router IDs to their correct IP addresses has resolved the issue.
Users browsing this forum: infabo and 150 guests
