broderick
DHCP lease for the gns3 VM on ether1. Why?
Tue Jan 03, 2023 12:55 pm
Hi and a Happy New Year to everyone,
I created a few Mk virtual devices on GNS3, and the project is growing up over time; I added wireguard tunnels to the original VLAN setup.
I noticed a strange dhcp lease for gns3 on the ether1 which also is the trunk port plugged to the "switch/ap" as shown by the image below:
Here is a screenshot of the lease window too:
As you can see, all the leases are for the green vlan, the first twos as expected, but I didn't understand where the last one comes from, even though the status is on "offered".
My MK setup:
add frame-types=admit-only-vlan-tagged name=BR1 protocol-mode=none \
    vlan-filtering=yes
set [ find default-name=ether1 ] comment=TRUNK
/interface wireguard
add listen-port=13231 mtu=1420 name=WG-Mikrotik-A
/interface vlan
add interface=BR1 name=BASE_VLAN vlan-id=99
add interface=BR1 name=Blue_VLAN vlan-id=30
add interface=BR1 name=Green_VLAN vlan-id=10
add interface=BR1 name=Red_VLAN vlan-id=20
/disk
set sata1 disabled=no
add name=WAN
add name=VLAN
add name=BASE
set [ find default=yes ] authentication-types=wpa2-psk mode=dynamic-keys \
    supplicant-identity=MikroTik
add name=Green_POOL ranges=10.0.10.2-10.0.10.254
add name=Red_POOL ranges=10.0.20.2-10.0.20.254
add name=Blue_POOL ranges=10.0.30.2-10.0.30.254
add address-pool=Green_POOL interface=Green_VLAN name=Green_DHCP
add address-pool=Red_POOL interface=Red_VLAN name=Red_DHCP
add address-pool=Blue_POOL interface=Blue_VLAN name=Blue_DHCP
/port
set 0 name=serial0
add bridge=BR1 frame-types=admit-only-untagged-and-priority-tagged interface=\
    ether3 pvid=10
    ether4 pvid=99
    ether2 pvid=30
add bridge=BR1 frame-types=admit-only-vlan-tagged interface=ether1
/interface bridge vlan
add bridge=BR1 tagged=BR1,ether1 untagged=ether4 vlan-ids=99
add bridge=BR1 tagged=BR1,ether1 untagged=ether2 vlan-ids=30
add bridge=BR1 tagged=BR1,ether1 untagged=ether3 vlan-ids=10
add bridge=BR1 tagged=BR1,ether1 vlan-ids=20
add interface=ether5 list=WAN
add interface=BASE_VLAN list=VLAN
add interface=Blue_VLAN list=VLAN
add interface=Green_VLAN list=VLAN
add interface=Red_VLAN list=VLAN
add interface=BASE_VLAN list=BASE
/interface wireguard peers
add allowed-address=192.168.32.2/32,172.16.11.0/24,172.16.31.0/24 comment=\
    SITE_B interface=WG-Mikrotik-A persistent-keepalive=25s public-key=\
    "VjH/0AdK9cMNdE7ehJ1aFeFjbzCBBpxm9wJVgfQ="
add address=10.0.10.1/24 interface=Green_VLAN network=10.0.10.0
add address=10.0.20.1/24 interface=Red_VLAN network=10.0.20.0
add address=10.0.30.1/24 interface=Blue_VLAN network=10.0.30.0
add address=192.168.99.1/24 interface=BASE_VLAN network=192.168.99.0
add address=192.168.32.1/24 interface=WG-Mikrotik-A network=192.168.32.0
/ip dhcp-client
add interface=ether5 use-peer-dns=no
add address=10.0.10.0/24 dns-server=192.168.99.1 gateway=10.0.10.1
add address=10.0.20.0/24 dns-server=192.168.99.1 gateway=10.0.20.1
add address=10.0.30.0/24 dns-server=192.168.99.1 gateway=10.0.30.1
set allow-remote-requests=yes servers=1.1.1.1
    invalid
    connection-state=invalid
add action=accept chain=input in-interface-list=WAN src-address=192.168.3.100
add action=accept chain=input comment="Allow Estab & Related" \
add action=accept chain=input comment="defconf: accept ICMP" disabled=yes \
    protocol=icmp
add action=accept chain=input comment="Allow DNS services" dst-port=53 \
    in-interface-list=VLAN protocol=udp
    in-interface-list=VLAN protocol=tcp
add action=accept chain=input comment="Allow Green_VLAN" in-interface=\
    Green_VLAN
add action=accept chain=input comment="Allow Base_Vlan Full Access" \
    in-interface=BASE_VLAN
add action=accept chain=input comment="WIREGUARD port" dst-port=13231 \
    protocol=udp
add action=accept chain=input comment="input Green_VLAN from WG-B" \
    src-address=172.16.11.0/24
add action=accept chain=forward comment="Allow Estab & Related" \
add action=accept chain=forward comment="Forward from Green to Green VLANs" \
    dst-address=172.16.11.0/24 src-address=10.0.10.0/24
    dst-address=10.0.10.0/24 src-address=172.16.11.0/24
add action=accept chain=forward comment="VLAN Internet Access only" \
    connection-state=new in-interface-list=VLAN out-interface-list=WAN
add action=accept chain=forward in-interface=BASE_VLAN out-interface-list=\
    VLAN
add action=drop chain=input comment="drop all else" log=yes log-prefix=\
    drop_in
add action=drop chain=forward comment=Drop log=yes log-prefix=drop_forw
add action=masquerade chain=srcnat log=yes out-interface-list=WAN
/ip firewall service-port
set ftp disabled=yes
set tftp disabled=yes
set irc disabled=yes
add disabled=no dst-address=172.16.11.0/24 gateway=WG-Mikrotik-A \
    routing-table=main suppress-hw-offload=no
add disabled=no distance=1 dst-address=172.16.31.0/24 gateway=WG-Mikrotik-A \
    pref-src=0.0.0.0 routing-table=main scope=30 suppress-hw-offload=no \
    target-scope=10
/ip service
set telnet disabled=yes
set www disabled=yes
/system identity
set name=RouterSwitchAP
/tool mac-server
/tool mac-server mac-winbox
set allowed-interface-list=BASE
/tool romon
set enabled=yes
It is not a big deal actually since everything runs in a virtual environment, but I'd like to understand what is going on nonetheless.
Could you please help figure it out? Thanks
Users browsing this forum: BoraHorza, GoogleOther [Bot], kormenator and 193 guests
