farai
Cannot PING or access router after firewall filter
Tue Jan 03, 2023 4:18 pm
Hie Mikrotik family
I was working on some firewall configurations till l entered the command
"ip firewall filter add chain=input action=drop in-interface=[Interface Name]"
The interface name l entered was a running one and seems to have been allowing all traffic to the router. Since that command, l can no-longer access the router via web GUI and cannot even ping the router. I would like to know how l may regain access to the router and revert that change. I have tried telneting into the router (using default port 23) but that doesnt work as well.
Selbie
Re: Cannot PING or access router after firewall filter
Sat Jan 14, 2023 3:47 am
You have probably locked yourself out; dropping every connection
You can try to connect to the webinterface from another interface.
If that doesn't succeed try either; the console / reset button.
Reset button will reset the whole configuration.
Note; in WinBox there is a safe-mode that might be handy to prevent this in the future
mkx
Sat Jan 14, 2023 11:25 am
You can try using winbox and MAC connectivity - after (if) winbox discovers device, click on displayed MAC address instead of IP address. MAC connections are bypassing IP firewall (access control is configured elsewhere).
anav
Sat Jan 14, 2023 3:45 pm
This is why I created my off the bridge approach to configuring the router ( for beginners ).
Read this here so that when you reinstall your config, this will happen far less.....
I made this post just for you!! ( twas me in the past )
viewtopic.php?t=181718
Users browsing this forum: Amazon [Bot], Michiganbroadband and 55 guests
