geofflamont
Voice VLAN
Tue Jan 03, 2023 5:04 pm
Hi, I am looking into building a network with several CRS354's and 328s. I am going to need to patch pc's off of Yealink T46S phones and am wondering if these switches have an equivalent of the Cisco voice vlan setting so I can give my VoIP and PC's different VLANs? Has anyone setup anything similar with these switches? The docs seem a bit ambiguous.
pcunite
Re: Voice VLAN
Fri Jan 06, 2023 8:58 pm
I use CR328 for this purpose. The MikroTik automated way is here. However, I just use hybrid ports.
SPKA16
Re: Voice VLAN
Fri Jan 06, 2023 9:12 pm
You mean voice network with LLDP. That's a hidden feature we long awaited for which you can find in IP/NEIGBORS for quite a while now.
https://help.mikrotik.com/docs/display/ ... figuration
As long you have your ports tagged with the voice-vlan and use this LLDP-MED (lldp-med-net-policy-vlan) with the vlan-tag of the VoIP-vlan all phones will use that vlan tagged on the switchport. Works just as 'voice' in vlan with Cisco/HPE etc.
cfikes
Re: Voice VLAN
Fri Jan 06, 2023 9:13 pm
Mikrotik does support a LLDP MED to assign voice vlans.
https://help.mikrotik.com/docs/display/ ... +discovery
In Winbox you will find the setting under IP -> Neighbors -> Discovery Settings
In the CLI
/ip/neighbor/discovery-settings/set lldp-med-net-policy-vlan=YOUR_VOICE_VLAN discover-interface-list=YOUR_INTERFACE_LIST protocol=lldp,cdp,mndp
cfikes
Re: Voice VLAN
Fri Jan 06, 2023 9:16 pm
Didn't mean to double post, must have been typing at the same time, apologies!
jrosetto
Re: Voice VLAN
Thu Apr 13, 2023 4:20 pm
Can you elaborate on how to set this up?
Simply tagging the voice vlan on all ports of the switch and configuring LLDP-MED to the vlan ID doesn't seem to do anything. I am using Yealink phones and they always end up on the default vlan.
mducharme
Trainer
Trainer
Re: Voice VLAN
Tue May 16, 2023 1:04 am
What you have done should do exactly that. Perhaps the config file for your phones is setting them to ignore the VLAN received via LLDP-MED.
Users browsing this forum: Ahrefs [Bot] and 7 guests
